saw a gunmetal R33, and a silver R34 (wingless) at the lights near BP phillip about an hour ago...
yeah gunmetal woulda been me i work in phillip cars of the road atm the gasket for the turbo shat its self so massive air leak yay spotted DTS's work being shit
https://www.sau.com.au/forums/topic/30059-spotted/page/486/#findComment-3940732
yeah gunmetal woulda been me i work in phillip cars of the road atm the gasket for the turbo shat its self so massive air leak yay spotted DTS's work being sheit
https://www.sau.com.au/forums/topic/30059-spotted/page/486/#findComment-3940734
spotted me sitting at trojan now waiting for a tow truck, stupid clutch pedal breaking... who breaks a clutch pedal jeez heh.
Nice ride Mate. Its a shame about the snapped weld. Hope its not too big a drama to sort out. Interested to see how it goes
https://www.sau.com.au/forums/topic/30059-spotted/page/486/#findComment-3950376
