Spotted Silver R32 GTR in City West Carpark. I love hammering it through there, setting off alarms.
Ha ha that was me and I agree! I got stuck in there the night before - didn't realise they shut it all up at 9!! That was some expensive parking!
https://www.sau.com.au/forums/topic/30059-spotted/page/490/#findComment-3993784
Yeh I thought it might be you. Nice ride, first time I have seen it. I am keen as to meet all you SAU tragics once my ride gets through the f**kwit circus (RTA Dickson). What did they Charge you? I got stuck in there with a flat battery once after paying for parking and had to pay again to get my car out and pay for the parking of friend who came in for 5min to jump start me. Robbery!
https://www.sau.com.au/forums/topic/30059-spotted/page/490/#findComment-3995119
white 33 heading down northbourne into flemington road, think he might have been heading toward trojan.
Good to see you were as frustrated as i was with other drivers on that road, sorry for the fly by i wasnt trying to be an idiot just letting everyone know they were driving to slow for that road.
https://www.sau.com.au/forums/topic/30059-spotted/page/490/#findComment-4001345
Spotted me getting over rego at dickson. Rocked up 15min late, disturbed them as they were having lunch. Passed! I'm free!!!! No more permits! Can't wait to get involved and see you guys at some of the events!
Edited by naughtyruski
https://www.sau.com.au/forums/topic/30059-spotted/page/490/#findComment-4005625
woohooo I bet that feels great to get out of the way, grats 2u.
https://www.sau.com.au/forums/topic/30059-spotted/page/490/#findComment-4005675
congrats! i know how happy you'd feel cos i went through a similar thing at the end of last year and beginning of this year, although i managed to not need permits
https://www.sau.com.au/forums/topic/30059-spotted/page/490/#findComment-4005689
Thanks guys, yeh its a massive relief, they just gave me so much grief before, had to change stuff etc and then they werent happy with the changes. They didnt like my engineers certificate the first time . Anyways its all done I have plates now and rego and i dont have to take anymore days of work to chase up parts and I can enjoy my new ride! :P
https://www.sau.com.au/forums/topic/30059-spotted/page/490/#findComment-4005783
What on EARTH is a (and I quote the badge on the back of the car): "NISSANPINTALINE" LOL. "GXE" model to be specific :D It had a bit of go! I was following it down Ginninderra Drive on the way home. Curious to know what the go with it is!
https://www.sau.com.au/forums/topic/30059-spotted/page/490/#findComment-4008010
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
