Spotted a BMW 535 with a few sad attempts to race the 2.5L twin turb 1jzgte going south on the Tuggers Xpressway...lmfao!
some people got not idea about the awesomeness that is the 1j :P
spotted a white 33 coming down college street. i gave thumbs up but didnt see a response
https://www.sau.com.au/forums/topic/30059-spotted/page/578/#findComment-4794133
Spotted Yellow 34 right out the front of erindale leisure centre as I drove past blinding them no doubt.
Also, some piece of shit (pardon the language) thinking he's f**king funny spitting on my car as he drives beside me in traffic coming down erindale drive - HAHA f**kWIT DIDN'T EXPECT ME TO SEE YOU DO IT HUH? BET YOU DIDN'T EXPECT ME TO GET YOUR PLATES AND MAKE/MODEL EITHER?
Good work to the above dipshit, you'll get your own.
Look at it this way Troy - anyone that would spit on someone else's car inevitably has more than their fair share of problems, so imagine how much it sucks to be them.
Spit is temporary, being a bogan loser dickhead is forever........
https://www.sau.com.au/forums/topic/30059-spotted/page/578/#findComment-4794418
spotted a black 33 with plates YGH05X being a FULLY mad SIKKENT trying to pick a fight with an old man outside woden cos he was too impatient to wait for the old guy to move his car.
who ever it is if they are on this site YOU are an absolute HERO. people like you seriously need a reality check. i woulda loved to have you slapped you across the face except you were to busy doing burnouts infront of babars.
C0CK!!
Edited by DUU MA
https://www.sau.com.au/forums/topic/30059-spotted/page/578/#findComment-4798513
Spotted maroon R33 and then white R33 30 seconds later on Monaro hwy headed north just after the roudabout @ rose cottage, driver of the maroon wearing headphones....I feel your pain buddy :P
oh, wait in my mummy's VW golf lol, getting lift to work while the wheels are at autotech
Edited by Trozzle
https://www.sau.com.au/forums/topic/30059-spotted/page/578/#findComment-4799987
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
