I could be wrong in my assumptions, but the owners of 34 and 35 GTRs in the area give the impression to me that they're too good for SAU...moreso, they give no impression at all, because while I am 99% certain they know of the website and forums, they never post or reply to spotted's...
ah well, such is life.
Think you'll find there's a lot of Skyline owners of all sorts that aren't on the forums. I owned Skylines for 6 or 7 years before I signed up. Didn't think I was too good for the forums but just wasn't as into the whole car scene at the time.
https://www.sau.com.au/forums/topic/30059-spotted/page/602/#findComment-5019324
You couldn't jump start it from the Audi or the daily?
Spotted a black R33 in the carpark opposite Mooseheads tonight.
I don't have the proper surge protector type cables to do it. I need to invest in a charger now that I don't drive it so often if I can't fix the slow drain that I have on the battery.
Spotted a purple R33 4 door yesterday at about 6:30 on Belconnen Way. Bodykit and wheels not really to my taste but the colour looks awesome!
https://www.sau.com.au/forums/topic/30059-spotted/page/602/#findComment-5033586
you alco shell.. drinking at mooseheads and it was only wednesday night... tisk tisk
lol Mooseheads wasn't even open... i was at King Omalleys... and I'm still on holidays so :thumbsup:
Also yellow R34 turning left from Ashley drive onto Johnson yesterday arvo, was from a distance so I couldn't tell who was driving it, though I assume probably not shell :thumbsup:
What time? Could have been me... i went to Calwell shops around 5-5.30pm
https://www.sau.com.au/forums/topic/30059-spotted/page/602/#findComment-5034066
spotted black R33 GTR with black rims and yellow decals. had ACT plates so i'm posting here.
Looked like a series 3. Saw it in Moss Vale around 3pm. I was in my FTO. Awesome looking car mate.
https://www.sau.com.au/forums/topic/30059-spotted/page/602/#findComment-5034669
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
