spotted a metalic pink R33 coming outta UAC this evening, chick driver
You mean UC? If so it was Me (Melly-too lazy to log in as me lol) I always spot heaps of skylines on my way too and from work in Mitchell and have seen a white 34 at Uni a few times.
https://www.sau.com.au/forums/topic/30059-spotted/page/611/#findComment-5118330
Spotted white 33 GTSt on Deamer in Richardson, was driving down the hill. I was on my bike out the front of my house - gave a wave but don't think you saw me...then saw what I think to be the same car up the other end of the street....had a SAU sticker on the windshield so I know you're here somewhere :D
https://www.sau.com.au/forums/topic/30059-spotted/page/611/#findComment-5123784
hey im a n00b on this forum, just wondering if you guys still meet at the museum? or if you do any friday night cruising. i remember cruising out to uriarra tracking station with you guys a few years back in a mates car. Ive just bought it off him.
https://www.sau.com.au/forums/topic/30059-spotted/page/611/#findComment-5129413
Try this thread:
http://www.skylinesaustralia.com/forums/Fr...&start=1920
If you search in there you should be able to find the location of the meet
https://www.sau.com.au/forums/topic/30059-spotted/page/611/#findComment-5129686
Spotted a black R33 down near Tuggies pool, waved out the window, got snobbed :(
Also spotted another black R33 which I thought was the first one again so I didn't wave :cool: so if you have blonde/surfie hair and drive a black R33, sorry for no waves :blush:
Also as I was leaving the Hyperdome, spotted a guy in a Datto 1200 ute looking at my car instead of where he was going and smashing into a gutter :P (ok, probably not funny, but meh)
https://www.sau.com.au/forums/topic/30059-spotted/page/611/#findComment-5130684
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
