Also spotted myself this morning dropping the 33 off at inline...can't wait to get her back on friday, gonna be a whole different car! especially considering the total damage to my wallet comes in at roughly $3700, it'd wanna be good! Who wants to go for a drive this saturday? lol
https://www.sau.com.au/forums/topic/30059-spotted/page/617/#findComment-5179586
it will be well worth it! mine gets finished on friday finally! what are you getting done to it?
https://www.sau.com.au/forums/topic/30059-spotted/page/617/#findComment-5180407
Spotted black 33 on drakeford drive this arvo at the erindale dr intersection. Gave a wave, got one back :D
haha that was me :D . I saw a burgundy(well lets say maroon) r33 outside of lanyon maccas around 1:00am this morning. May have been leaking something as it left a trail after it parked for a few . could have just been there already though not to sure.
https://www.sau.com.au/forums/topic/30059-spotted/page/617/#findComment-5181378
Can you let me know what you think of their work v costs/value for money. as i am considering Getting them to sort out some bits and bobs for my pulsar.
https://www.sau.com.au/forums/topic/30059-spotted/page/617/#findComment-5181937
I'd say many people here (ZCR, Turismo, GTRKat+many others) could vouch (and likely will) for Chris and the team's work at Inline - it's the main reason I've taken my car there. Of course I will post up results+thoughts once I'm done.
Only negative thing's I've heard about them is that you obviously pay proportionately for the work you're getting - meaning they're reputed as expensive but well worth it, and that Chris has a tendancy to go a little over the top, and have parts replaced that don't 100% need to be. That being said, if you're going to spend some money, and want good results, I've heard it's the right place.
https://www.sau.com.au/forums/topic/30059-spotted/page/617/#findComment-5181989
Thats cool
Plan is to replace Shitty and way too stiff D2's for TEIN in the Pulsar. Every other bush, link, brace, nut and bolt that can be changed has been done by a well known and trusted suspension shop in sydney. Appears the last owner ran out of coin when it came to the coilovers.
Well i will look forward to your feedback (and getting his quote).
https://www.sau.com.au/forums/topic/30059-spotted/page/617/#findComment-5182221
spotted a very menacing black R33 in Weedon Close at ~430 this arvo.. it was very black, super dark tint, nice body kit and gold GT-C rims.. looked fkn mint.. for a 33 :ninja:
also spotted a silver Stagea right after that next to Rubies turning into Weedon Close
https://www.sau.com.au/forums/topic/30059-spotted/page/617/#findComment-5182362
Spotted white 33 this morning parked across from Hyperdome on Anketell....License plate reads YFZ-33E
Why did I take note you ask? Well mine reads YFZ-33H
Coincidence? I think not! Conspiracy I say!!! Government is pulling some funny shit here on me.
https://www.sau.com.au/forums/topic/30059-spotted/page/617/#findComment-5185706
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
    • Its a well known brand in New Zealand; its a rebrand of the Rhino RAV3.  I don't know what the wiring difference *is* between the rev.1 (installed about 15 years ago) and rev.2; but as you say I would think its reasonable that it uses the same immobiliser relay circuits. I had a look but couldnt see a similar harness; but didnt move things around since I didnt want to mess with it   It was one of AVS well known Authorised Installers; I spoke to AVS themselves about it but theyre unsure hence seeking advice more so from the skyline community who are more familiar with the actual car and its wiring. Im in Auckland; but the installer is on the other side of the city so hes very reluctant to come back to even look at it to confirm something isnt connected into the wrong wire.  I dont want to drop the name since they *did* do a really good job for the most part. Everything is very tidy and he fully replaced all the alarm wiring, all the sensors, the wiring to the door motors, installed a switch which was never installed in the first place...really happy with the alarm install itself..just not this one issue. We all make mistakes, if it is the alarm, I just want my fuel pump getting proper switched, fused, power as it was; without having to shell out for an auto electrician to switch a wire and tell me it was the alarm.
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
