hmmm yeah we'll rip it off and get the pro's to look at it
Heh, I spotted you doing this for Trozzle out the front of his place. (well I assume it was your work van parked near by)
I also drove right past Trozzle and waved at him but I was in the black beast which probably explains the weird look I got back. :devil:
https://www.sau.com.au/forums/topic/30059-spotted/page/638/#findComment-5497544
I also drove right past Trozzle and waved at him but I was in the black beast which probably explains the weird look I got back. :D
bahahaha yeah man was sitting there going "Why doesn't it feel weird that some random in an EVO waved at me...?" I knew that I knew who was driving, just couldn't think of where or why :)
https://www.sau.com.au/forums/topic/30059-spotted/page/638/#findComment-5497821
14th Oct my son God_speed's GT-R got rear-ended at 6pm by a Porsche
18th Oct I took his car to Nepean Valley Smash for a quote to go to Guild Insurance
18th Oct The panelbeater says he saw all these R32s coming down the Gt Western Hwy about 5pm on Sunday 10th Oct - ACT plates - & well-behaved!!! :)
https://www.sau.com.au/forums/topic/30059-spotted/page/638/#findComment-5507145
Geez Terry,
I hope Matt's R33 is not too badly damaged, but I hope the Porsche is :D
Thanks :( Mick,
The Cayman ran up the back of a Commie which went up the back of a Suzuki which went into the back of Matt's R33 GT-R.
It looks like minor cosmetic damage only. Reo/bever panel will need replacement as well as the bar. So not too much.
Matt will probably be offloading the GT-R soon, as he's buying my R34 GT-R. I'm committing myself to a Bayside Blue VS2.
Nissans are under my skin a bit more than Matt, as he's still quite keen on Beemers too.
What comments (criticisms as well as compliments) did your boys have about the 21st? Different hairstyles back in the early 90s eh?
https://www.sau.com.au/forums/topic/30059-spotted/page/638/#findComment-5509567
As if you were going to sneak that past me!!!!
I do indeed like blue although I try to keep as much colour out of the engine bay as possible these days. I do still like to try to aim for semi stealth and stock although that is getting harder and harder :)
https://www.sau.com.au/forums/topic/30059-spotted/page/638/#findComment-5510019
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
