ah, so when I gave it a little bit.
I don't give it any boost before that point due to engine not being at acceptable temperature lol....can you see why I don't enjoy the drive to work? fking boring :ermm:
couldnt tell, whaleness offsets quickness...
https://www.sau.com.au/forums/topic/30059-spotted/page/648/#findComment-5567355
