Yep was me and Nathan.
Didn't see your car, were you in the 32?
I wish, its got a few cosmetic issues to fix after i decided i wanted a new front bumper haha :(
I was in a red over silver vl (yeah i know, its a bucket haha)
Edited by k_d
https://www.sau.com.au/forums/topic/30059-spotted/page/678/#findComment-5919668
Does anyone have a red 32 or 33 and was parked at the Richardson preschool.... has a sticker and QLD plates apparently.
My friend got all mega excited cos it was a Skyline and felt the need to tell me about it lol
https://www.sau.com.au/forums/topic/30059-spotted/page/678/#findComment-5920277
