yeah, spotted heaps of Skyrines on the way home yesterday.
James, your 31 looks fair decent, suspension looks way firm...... Good for Dorifto!!!!11
but what the hell happened to the old boosted Red Silo?
https://www.sau.com.au/forums/topic/30059-spotted/page/680/#findComment-5939463
Gray r34 (Sinista?) & r33 with domo kun hanging off the back from city to tuggerz. we were all driving like grandmas fuel expensive these days . i was in black r34 with p plates.
Yes Sinista (Jnr) in the pilots seat of the 34 as the black supra is being readied for a bigger heart (1jz to 2jz). Mini cruise looks good .
Some times when you go slower it gives the impression your car is a beast waiting to unleash :thumbsup:
I've seen cars race up beside and then back it off.
https://www.sau.com.au/forums/topic/30059-spotted/page/680/#findComment-5941591
Spotted and waved to Jimmy this morning... Heading up the hill towards Calwell.
I didnt get a wave back :( (I was driving my 4WD though).
Hahahaha 4WD's are not relevant to my interests, sorry mang... :D
besides, i'm usually still heavily asleep while i'm driving to work....
https://www.sau.com.au/forums/topic/30059-spotted/page/680/#findComment-5949076
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
