;) good to see I'm being noticed, not for the wrong things haha
Is that the Pearl White one?
If so....mint car...I followed you into Woden Westfield one evening...was popping flames out the pipe just idling around...but I must say needs MOAR tyre under the bum....wheels are right....but I hate tyre stretch lol
https://www.sau.com.au/forums/topic/30059-spotted/page/688/#findComment-6022181
Spotted the black RS4 in Tuggers....which driver might possibly go to Anytime gym there? Just a guess.
Yahh.. that would be me.
Spotted a RS4 queuing up at the round-about at Tuggeranong (drakeford/athlon) this morning. I was about to drive past, but merged just before I got in line.
https://www.sau.com.au/forums/topic/30059-spotted/page/688/#findComment-6024238
Awesome, I've seen you drive that way a few times now. You drive through my neck of the woods hey?
Yep as this is my daily you would see me down south quite often teasing the Falcodores and Ute wank%&s
https://www.sau.com.au/forums/topic/30059-spotted/page/688/#findComment-6024342
So you hit anytime eh? Say hi if you see me! I can't really give you any distinguishing features though lol....eyebrow piercing, 2 studs left earlobe, 1 ring upper left ear. I'm there most evenings around 7 or later
https://www.sau.com.au/forums/topic/30059-spotted/page/688/#findComment-6024395
Yeah no worries man.. I havent got many distinguishable features... 16mm holes in my ears, 3 stars tattooed around my neck and half a sleeve. Average joe i suppose.
https://www.sau.com.au/forums/topic/30059-spotted/page/688/#findComment-6024404
Spotted 2 R33 GTS-T's tonight.
One on Canberra Ave going into QBN, I noticed both guys checking out my R32. Hope you boys got a good look.
And the other was parked in the relief rd carpark for Crawford Rd. That one was a 4 door :)
https://www.sau.com.au/forums/topic/30059-spotted/page/688/#findComment-6024511
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
