spotted a yellow 34 gtt heading towards tuggers on drakeford just now.
i think they waved but i didn't see it til too late and didn't have time to wave back :(
my bad
was distracted by the convo/argument me and jess were having about time travel haha
https://www.sau.com.au/forums/topic/30059-spotted/page/707/#findComment-6161010
Just got home from work and spotted the young bloke's R33 with three well keyed panels and a slashed tyre - brand new Federal RS-R.
Words can't describe what I would do to the pricks that did that if I ever found them. :domokun:
https://www.sau.com.au/forums/topic/30059-spotted/page/707/#findComment-6161032
Sounds personal John. Ask your son why/who......
Happy to help then sort the bastards out.
I know this because it happend to my car when scum wanted to get at one of my sons.
(randoms dont key 3 panels & slash a tyre)
https://www.sau.com.au/forums/topic/30059-spotted/page/707/#findComment-6161062
Thanks folks, looks like the mofo's have shoved a pocketknife or screwdriver through the sidewall so I doubt that can be repaired, so he'll be off to pick up a new tyre tomorrow. I think they were 225/40 18's, about 2 weeks old (early xmas present).
https://www.sau.com.au/forums/topic/30059-spotted/page/707/#findComment-6161169
my bad
hey, that was me, i waved but it was at the last moment so i didn't think you noticed.
https://www.sau.com.au/forums/topic/30059-spotted/page/707/#findComment-6161432
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
