Spotted myself cracking the shits with a taxi driver on Athllon dr/Hindmarsh dr lights this evening. Are they allowed to use the bus lane for traffic lights? Or are they just being wankers? I assume (and believe) the latter, which is why I gave him the finger big time. f**king twats.
Also getting tired of dose.
zututututututututututututu
https://www.sau.com.au/forums/topic/30059-spotted/page/716/#findComment-6224816
Yeah they're allowed to Troy. Same for motorbikes.
Would you like some anger management classes? :nyaanyaa:
Are you serious? Why the f**k do motorbikes get to use it?
I'm talking about the lane to the far left, the one that triggers a B for BUS. Last I checked taxi doesn't start with a B.
Either way they can get f**ked. Buses run to a schedule and need to keep to it. Taxis have no need for it, the customer can suck a dick. Motorcycles have absolutely no reason at all, not like they don't already skip half the traffic by illegally using the shoulder on roads.
I don't so much need anger management, the world just needs less retarded bullshit and f**kheads.
https://www.sau.com.au/forums/topic/30059-spotted/page/716/#findComment-6225034
Yeah I know which ones you're talking about.... I don't know why they can, but they can.
Buses, taxis, public hire cars & motorcycles can use any of the bus lanes, except the ones in interchanges and shit.
https://www.sau.com.au/forums/topic/30059-spotted/page/716/#findComment-6225088
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
