That 32 GT-R out the front of woden is ALWAYS there. like every day : | do we know who owns it?
Spotted a white 32 GTR parked out the front of Woden Cinemas.
Also on my way home about 9:15 I followed a silver 33 GTR which turned off into O'Malley
https://www.sau.com.au/forums/topic/30059-spotted/page/724/#findComment-6264690
spotted black series 1 r33 flying though narrabundah on what must have been 22inch or more bob jane chromes
f**k I wish I could sell them and buy something not so bad
They are 19" and trust me I don't want them
Anyone keen to buy them haha
Spent all my money on the engine parts
https://www.sau.com.au/forums/topic/30059-spotted/page/724/#findComment-6268507
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
