It was a female driving.
I was going to say, pretty sure it's a female that drives the orange 33. I see it basically every morning heading in the opposite direction to me when I'm driving to work. I'd wave but I'm never in the skyline, so she'd probably think I'm just some chump trying to pick her up.
Wonder if it's the ex J-racing car? Certainly looks like it.
Not a skyline, but spotted a brand new looking Ford Super Duty F-350 at Perisher today... So big and so so awesome. Size does matter when it comes to those things...
Edited by Amaru
https://www.sau.com.au/forums/topic/30059-spotted/page/757/#findComment-6523831
Ok ... My apologies to the lady driving the orange 33, I usually dont miss those basics but come to think of it every time I have spotted it it's been parked. But you are right Shell, it does stand out and it does take a while to get over it.
https://www.sau.com.au/forums/topic/30059-spotted/page/757/#findComment-6523986
Spotted a white de-winged R33, stock rims on front & somethin' else on the rear, NSW plates, on the GDE after 1pm today.
Driver made a point of blowing off beside me. Sounded like an old Volkswagon and it didn't idle well.
Wish I was going straight at the lights as I would've smashed him. :D
Spotted a white R33 GTR? 20mins later near the Gungahlin Lakes Club.
https://www.sau.com.au/forums/topic/30059-spotted/page/757/#findComment-6524951
Spotted a silver R34 GTT on Athlon this morning at about 0810 heading towards town.
Didn't know to wave or not as I'm not your typical youngun. Nice 33GTR you have. :action-smiley-069:
I shoulda jumped earlier to get in front of the truck. Missed every other light all the way into the city :(
https://www.sau.com.au/forums/topic/30059-spotted/page/757/#findComment-6525515
Niether am I, I guess. Over 40 etc.
Same here, every light then people doing 80 in 100 zone on the Parkway. :verymad:
I will wave next time, I was going to but didn't get a chance as you passed me when I pulled to the left.
Thanks, nice R34 GTT too mate.
https://www.sau.com.au/forums/topic/30059-spotted/page/757/#findComment-6525518
Mine needs a good clean. Bloody rain and dust.
I'll wave nest time although I was running later than usual this morn.
I hate the traffic heading into town between 7.15 and 8.30am. Absolutely ropable when I get to work.
https://www.sau.com.au/forums/topic/30059-spotted/page/757/#findComment-6525965
Just as a matter of interest how many other 'non typical young-guns' , I.e. over 40's in here?
https://www.sau.com.au/forums/topic/30059-spotted/page/757/#findComment-6526601
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
