I didnt spot the Banana at your work today shell
and btw...I should be working in the same street as you :ph34r:
Oh awesome! Can you work the same hours so I can get lifts? :D
Nah I usually park on the premises behind the gates so you wouldn't see it from the street. It's only on the street if the sales reps have stolen all the spots.
https://www.sau.com.au/forums/topic/30059-spotted/page/760/#findComment-6531967
Spotted THE34T in traffic on Canberra ave yesterday arvo.
And a silver 34 with white enkei RP01's or similar in fyshwick at lunchtime today
Thanks mate .... I was just about to go with the green light when I spotted a glimpse of your grill in my side mirror, I looked around enough to see the front of a black Stagea, attempted a feeble wave and left the lights ... Seems like it was all in about 2 seconds.
https://www.sau.com.au/forums/topic/30059-spotted/page/760/#findComment-6539384
Keep spotting a gunmetal grey R32 GTR complete with Federal Tyres sticker and SKY32R plates outside my work in Woden.
Also spotted an orange R33 with a girl driving it, not sure of anyone else has seen it???
Edited by Amaru
https://www.sau.com.au/forums/topic/30059-spotted/page/760/#findComment-6540739
R32 is Reece
And no, nobody has seen her ever!
https://www.sau.com.au/forums/topic/30059-spotted/page/760/#findComment-6540918
Keep seeing a banana 34 GT-T heading down tharwa towards drakeford at around 735am
I'm in the noisy white commodore going the other way
That's me dude...
What colour is the bombadore?
https://www.sau.com.au/forums/topic/30059-spotted/page/760/#findComment-6540949
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
