I hit a roo :(
Dead centre at the front so the bonnet is all pushed up, grille is smashed, radiator etc etc
I can now see under the bonnet from the sides, even though it's closed, cos it curves up LOL
That sucks! hope it all gets sorted soon!
https://www.sau.com.au/forums/topic/30059-spotted/page/812/#findComment-6789937
It wasn't random at all - You were targeted by this active marsupial terrorist herd.
I think it's the same one that tried to get you in Shepperton during the the SAU Nationals 2012 ??
Conspiracy Theory !!!!
X fingers insured .............
(Ps. Roo distracted by glow from sun burnt bewbs)
https://www.sau.com.au/forums/topic/30059-spotted/page/812/#findComment-6789970
Haha I think they're all out to get me.... I've had many near misses since Shepparton. Usually I can see them coming and work out a manouvre but this one came out of nowhere... I think it literally jumped out of the dark to a few cms in front of my car in one leap.... hit it at 80km with no time to brake :(
https://www.sau.com.au/forums/topic/30059-spotted/page/812/#findComment-6790090
I hope you took it to the hospital.
https://www.sau.com.au/forums/topic/30059-spotted/page/812/#findComment-6790259
Roos are always sneaky jumpers ! I've learnt that their defensive tactic is to "confuse" a predator by immediately changing their direction when they hop along; which is why a lot of cars hit them which is why a lot of Roos hit cars.
Did the Roo have insurance?
Edited by Jeremy90
https://www.sau.com.au/forums/topic/30059-spotted/page/812/#findComment-6790461
If the front was smashed in, the yellow one might have been me :(
it was in the morning around 8:20am the yellow was heading down towards wanniassa. From the damage your talking about its wasnt you unless if im getting blind.One jumped infront of the car in Hume early morning hours was very lucky i was going slow enough to stop.
Edited by B-rice
https://www.sau.com.au/forums/topic/30059-spotted/page/812/#findComment-6790645
I need to make sure im covered if i hit a roo.JustCar doesnt cover me from what ive just seen but im also too young for Shannons or any other one willing to insure a youngen. If i ever hit one ill make sure it doesnt die so that I tortue it later on for the damage.
https://www.sau.com.au/forums/topic/30059-spotted/page/812/#findComment-6791134
I need to make sure im covered if i hit a roo. JustCar dont cover roos from what ive just seen but im also too young for Shannons or any other one willing to insure a youngen. If i ever hit one ill make sure it doesn't die so that I torture it later on for the damage
https://www.sau.com.au/forums/topic/30059-spotted/page/812/#findComment-6791136
The black R34 could have been me. Havent lived in Canberra long but yet to see another black 34. Seen heaps of Skylines around, wish I knew about this thread earlier on.
as i was exiting the richardson roundabout, i think i went over an oil patch and my car went sideways freaky shit. then in he middle of the struggle to gain control I spotted a black r34.i would like to thank the guys at fifth gear, otherwise would have panicked and written my car off
https://www.sau.com.au/forums/topic/30059-spotted/page/812/#findComment-6791838
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
