Spotted late this morning, a gunmettal R32 turning off Northbourne onto London, I was only behind it for a few seconds and gave a feeble wave thinking the driver probably wasn't looking at me in the rearview .... so it your on here .... :action-smiley-069:
Edited by THE34T
https://www.sau.com.au/forums/topic/30059-spotted/page/825/#findComment-6815405
