Passed Jimmy on Ohalloran Cct at about 3pm ;) Was going to flash you but wasnt 100% sure it was you till I got closer. HEADLIGHTS dirty people... headlights !!!
Hey, I can't spot you any more because you drive a rented euro box.
But yeah that would have been me.
https://www.sau.com.au/forums/topic/30059-spotted/page/834/#findComment-6851634
Welcome to Canberra. :)
Didn't notice :( *deflated*
Friday nights people normally head to Grevillia Park around 9.30pm for a chat
Sometimes like this and sometimes with a black bonnet and wingless.
Sorry i was distracted by the gps trying to find my way to woden
Ill have to check it out one Friday, wouldn't mind seeing what the Canberra scene is like.
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/834/#findComment-6851660
Midnight purple wingless 34 at j racing this morning
Also spotted an orange 33 with the middle strip of the bonnet painted black driving like a complete knob head in peak hour this arvo from mawson toward erindale, took it upon himself to run a red because there was a break in traffic going the other way, its people like this f**kwit that ruin the modified car scene for everyone and give us a shit name. I'm all for giving it a hit here and there and bit of spirited driving but sliding around every corner, running reds, massively tailgating and weaving traffic violently in the space of 5 mins is too much. Pull ya head in wanker.
https://www.sau.com.au/forums/topic/30059-spotted/page/834/#findComment-6855467
woohoo finally spotted
https://www.sau.com.au/forums/topic/30059-spotted/page/834/#findComment-6856456
Spotted silver r34 gtt with black wheels turning past Calvary n a black 32gtst thru the week. Both very tidy.
Was there a nismo sticker behind the GTT. Might have been me been me. Saw Helga with the new owner. How much did you see it for Jeremy
https://www.sau.com.au/forums/topic/30059-spotted/page/834/#findComment-6857163
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
