Spotted this pearlescent r33 in the canberra hospital carpark today. Looked like a bit of a bomb apart from the paint job and the rims. 10 bucks no one else has seen it though seeing as everyone is northside.. :mellow:
https://www.sau.com.au/forums/topic/30059-spotted/page/840/#findComment-6877745
If it's the green/gold/purple pearlescent R33, my understanding is that it's running an LS2 (6.0L V8) and can run 10s....though I swear the few times I've heard it running it definitely wasn't a V8 lol
https://www.sau.com.au/forums/topic/30059-spotted/page/840/#findComment-6878456
Given up officially spotting Jimmy who doesn't notice me even with flashing lights and whatever I can do to grab attention LOL!
Think I spotted RIchard in the GTR going opposite way to me on GDE or the parkway this morning.
Parked opposite a black stag with for sale sign on the back this morning too.
https://www.sau.com.au/forums/topic/30059-spotted/page/840/#findComment-6878471
Wow, guess I'll have to keep my ear out then..
https://www.sau.com.au/forums/topic/30059-spotted/page/840/#findComment-6879154
Let me correct you on this one budd. I own this car. It is running a nitrous Ls2 with a tricked up auto and lock diff. It has never seen the strip in this configuration so the times you mentioned are false. The car is not a show car, It gets driven daily hence its not always clean. The front bar lets the car down, but the rest of the car is clean.
https://www.sau.com.au/forums/topic/30059-spotted/page/840/#findComment-6881047
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
