Enjoy your long lasting engine if that's how you like to go about it...
They love it. It's all good. In the time i have owned the GTR it has spent more time in the shop than i have had it. Technically its first home is at ultimate tunes hahaha
https://www.sau.com.au/forums/topic/30059-spotted/page/843/#findComment-6886951
Red 34 in Mitchell (not Rosie) and pulled into Palmerston... 3:38pm. I flashed and waved... :(
Blue 33 S1? with Big Chromies on Kingsford Smith... 3:49pm. I waved... :(
Silver S2 R33 on Florey Drive 4:16pm... I waved... :(
https://www.sau.com.au/forums/topic/30059-spotted/page/843/#findComment-6887534
I am the ONLY red one here thank you ver much ! :(
https://www.sau.com.au/forums/topic/30059-spotted/page/843/#findComment-6887554
I've been waving heaps to peeps in QBN lately. There is a silver R33 GTR, a Silver R33 GTST which lives on Crawford Street and also a black R33 with Lightning on the side who's BIL I met lately.
Saw my 4Door getting downtuned today to 14psi after overboosting. Still made over 270RWKW at ESP. Who turns it down??? I do apparently. Don't hate me. I don't want it to go crunch.
https://www.sau.com.au/forums/topic/30059-spotted/page/843/#findComment-6887640
Maybe... It's cheaper Rent. + commute + ... Nah. Forget it. :D
It's funny though... Every other car I've had, I would always see those cars on the road.
(and there weren't that many 90's Bluebirds around)
Now I still see all of those previous cars, just not my current Baby...
It's kinda cool actually.
https://www.sau.com.au/forums/topic/30059-spotted/page/843/#findComment-6887662
Also for the 4Door clan, get this. There are 4, R33 4Doors in QBN. Mine, One on henderson/crest road (looks like a non runner), One on Cooma Street S1, and a non turbo KR4 S2 that I see occasionaly. Random huh.
Yep I see a couple of those 4 doors around all the time. Always surprises the hell out of me
https://www.sau.com.au/forums/topic/30059-spotted/page/843/#findComment-6887670
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
