Haha thanks, looks like you have a good base to start with :)
Yeah wtac was great, were you there?
Yeah i was there, pretty sure it was your car at the ibis where we stayed aswell. Wtac was awesome cant wait for next years.
https://www.sau.com.au/forums/topic/30059-spotted/page/886/#findComment-7091166
Yep that would have been me! Me and my mate stayed there. He owned the green 328i e36 :)
Next year should be great :D
https://www.sau.com.au/forums/topic/30059-spotted/page/886/#findComment-7091192
Do anyone have a daily car that they spot but never mention?
I see a R32 GTS every day of my life in my street and a 4door silver R33 ontop of roof parking in civic (every other day). Anyone park next to a regular every day or live near a other Skylines?
https://www.sau.com.au/forums/topic/30059-spotted/page/886/#findComment-7094417
It's a good idea not the to post the location of ones that are in the same spot every day. Just for the owners sake. You never know what scumbag thieves are reading this forum.
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/886/#findComment-7095141
So Shell quotes the original post without editing it, just to ensure said scumbags didn't miss it :P
https://www.sau.com.au/forums/topic/30059-spotted/page/886/#findComment-7095830
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
