Yeah was disgraceful.. wheel spin into slamming on the brakes before plowing into a bus.. he just swerved into oncoming lanes without any care in the world.. p plate.. looked like he'd crashed before.. makes us all look bad..
With a bit of luck a kangaroo of karma will fly thorugh his windscreen kick him in the face. Speaking of kangaroo's i escorted one down outrim ave calwell this morining when i was on the way to the gym. Had my hazards on going about 30 with a kangaroo infront of me. Got some wierd looks from oncoming traffic.
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/905/#findComment-7141344
f**k I would have sat behind you with my hazards on too!! I was got to Calwell around 7am ( to do some work for my grandad ) then mum drove it back to Yarralumla,
every skyline I see doesn't seem to be on SAU :(
Edited by ..::R33GTS-T::..
https://www.sau.com.au/forums/topic/30059-spotted/page/905/#findComment-7141734
this was 5:40am btw
https://www.sau.com.au/forums/topic/30059-spotted/page/905/#findComment-7141814
Had a 60 sec double spot!! :yes: pretty excited about that ....
at 11.55am today on Isabella Dve, heading towards Tuggers, a silver R33 S2 .. looked clean but we were both doing 80 in opposite diresctions so didn't see too much :closedeyes: .. then 60 seconds later (heading in same direction) a black R33 S1 (I think wingless) again going in opposite direction whilst I'm ploughing into a roundabout.
https://www.sau.com.au/forums/topic/30059-spotted/page/905/#findComment-7143060
    • Before starting any work, we attempted to adjust the tune. However even after adjusting it to certain extremes like completely stopping fuel, it had no effect. What fixed it was removing the Nistune Board and installing the original EPROM instead. This immediately fixed the issue. Everything should have been fine with the Nistune Board installation, so I am unsure why it has caused a problem. The soldered connector is also properly soldered. This worked when I first got the 550cc injectors, before cleaning, but that may have been a coincidence.  We ended up not installing the fuel pump hanger (at least for now). So currently running stock injectors, stock fuel pump, stock fuel pump hanger – Well everything stock except the exhaust. Now I have around €1400 in Nistune, Injectors, and Hanger collecting dust for the time being, perhaps I'll install them in the future. For now I'll enjoy the car as is 😁 Thanks a lot for all your assistance, I really appreciate all the help you have given me.
    • The turbo can’t be the issue. They’re proven to make much much power than you’re making. There is something in the setup that isn’t correct. - has the exhaust got any silly step downs? - what exhaust manifold?
    • Ok, just the way you wrote it made it look like you had the stagger the wrong way around
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
