f**king kangaroos....
first and final kangaroo experience if I can help it... now have flat spots on my tyres...
I haven't seen such a close call.... I have noticed they hide behind a tree/bush in the dark then say hello...
thank god I was doing 15kph under the speed limit for once....
seen a red r31 a couple of times recently, its actually so clean !
Edited by ..::R33GTS-T::..
https://www.sau.com.au/forums/topic/30059-spotted/page/906/#findComment-7144491
Thank Rajab indeed... :)
The guy I got my wheels off owns a very clean Red R31, could be him.
ok, im only going to ask this once....
what the flying f**k is rajab... i typed " G O D "
i googled it and it says its the seventh month of the Islamic calendar...
like that makes sence :(
its so nice, where does he live if you know? ( no stalker here bois )
https://www.sau.com.au/forums/topic/30059-spotted/page/906/#findComment-7144511
He lives out Southside.
Type in G o d, J e s u s, or L o r d and it Auto corrects to rajab. Some funny bugger has messed with it recently.
Various other words also Auto Correct. Usually swear words but anything related to a large bird associated with Christmas or Thanksgiving changes too...
Do try it. :D
https://www.sau.com.au/forums/topic/30059-spotted/page/906/#findComment-7144514
thank rajab I was doing 15kph under the speed limit for once....
yep "surprise roo" are the ones you have to worry about.... the ones you see eating just usually raise their head and give no fark. Both of the ones I've hit have jumped from the dark into the line of fire.
https://www.sau.com.au/forums/topic/30059-spotted/page/906/#findComment-7144545
why they hell do they have a death wish.. getting hit may not kill them but if they make a skyline hit them.. im sure they would die after the crash...
i wouldn't want to be a roo after jumping in front of a nice car...
a guy ( or girl who knows ) got a mouth full for throwing a mackers bag at my car in woden... then he ( or she ) took a piss beside it.. long story short i got the hell out of there quickly...
https://www.sau.com.au/forums/topic/30059-spotted/page/906/#findComment-7144548
Saturday parked at epic (kids xmas party?) about 10am - 3pm
white R34 GTT and Black R33 GTS-t
not sure if it was mine...
saw a white r33 with gold rims in Calwell around 7am today ( Pattey21 ? )
https://www.sau.com.au/forums/topic/30059-spotted/page/906/#findComment-7145007
Spotted in and around fyshwick:
Black or midnight purple 33 GTR near Commonwealth bank Australia in Fyshwick
Black R35 GTR leaving fyshwick heading towards the city
Silver R35 GTR heading south on the monaro next to the grass dudes (canturf?)
Was in #@Verms White autech stag.
https://www.sau.com.au/forums/topic/30059-spotted/page/906/#findComment-7145137
I didn't see any skylines on the road this arvo, but a dam nice grey s15 on volk te37`s looked sweet!!
and some preety good looking chicks looking at black beauty :D had a talk to one at the lights, we were listening to the same song haha.. mine sounded better with the numberplate rattling its head off :(
https://www.sau.com.au/forums/topic/30059-spotted/page/906/#findComment-7145293
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
