She gets out just fine. :woot:
She was driven yesterday and got a Grin and wave from some young P plater punk who then ate my exhaust and saw me disappear into the distance.
Also one of the Hot Chicks at the local Woolies Audibly Moistened when she asked "is that YOUR Skyline?" and I replied "Yeah...she's my baby". :P
and what woollies may this be? :) hopefully she like 2 doors :P
Edited by ..::R33GTS-T::..
https://www.sau.com.au/forums/topic/30059-spotted/page/913/#findComment-7157811
but I have this thing, for example, just before I was at kingsleys in Weston and when I was in side a couple of alright looking girls were walking around it looking at it, and being dark they couldn't see my mum in the car.... she winded down the window and said can I help you? f**k she finds new ways everyday to ruin my life haha
https://www.sau.com.au/forums/topic/30059-spotted/page/913/#findComment-7157814
Taken further...as in, in the Back seat, with easy access due to having 4doors. :rofl:
youseewhatIdidthere? :D
Yes mate, I saw what you did there ... an amusingly clever way, and one of the few opportunities, to justify having 4 doors, however well said and point taken.
My shout after that .. :cheers:
https://www.sau.com.au/forums/topic/30059-spotted/page/913/#findComment-7158259
Late, I know... (but hard to post with no internet !)
Silver 34 heading south into Cooma 1230 on 28/12 and...
white 34 (looking very lost) on Sharp Street in the centre of Cooma around lunch time, 29/12?
No responses.
Have to introduce you to some checkout chicks at Cooma Woolies Rob....you'll do more than a few laps (trying to get away!!!)
https://www.sau.com.au/forums/topic/30059-spotted/page/913/#findComment-7159040
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
