Spotted an R34 GTT/R. Not sure as I had to cock my head back from 12 to 6 and by then he took off. He looked at me a few times but I was a lil slow on the wave.
Not exactly sure where, but heading to the city past ANU / Stadium.
Edited by RosieR34
https://www.sau.com.au/forums/topic/30059-spotted/page/934/#findComment-7250997
Uh oh :( What happened?
Over the last few years the engine has had to sit unused, sometimes without oil, while I slowly swapped the turbo, intake manifold, and a bunch of other stuff, plus the years of abuse before that.
Finally got everything installed, got it to tune, made good power. day before I went to pick it up, it started pissing out oil smoke. a little on idle, alot under load and when backing off. Looks like its engine. People reckon rings and or valve stem seals.
Now with baby in the way, I dont have money for a replacement.
Yay cars!
https://www.sau.com.au/forums/topic/30059-spotted/page/934/#findComment-7253452
Yay cars!
If its valve stem seals I have the tools to change them without removing the head off. Mine did the same when backing off turned out I had to rebuild my turbo but had changed the seals before and it wasnt the problem.
https://www.sau.com.au/forums/topic/30059-spotted/page/934/#findComment-7254767
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
