Nope. It was clearly setup for track use and tbh all the specs that I saw on it would've enhanced the track experience. Also the fact it has a Nulon sticker my guess is that it went to the Nulon Airport runs or maybe even WTAC. I'm not a fan of the big wings and such but when used for the track then much respect for the build is given.
https://www.sau.com.au/forums/topic/30059-spotted/page/960/#findComment-7417769
Was this the one you've seen? i see it fairly often around belconnen
If so its actually set up as a time attack car, stripped interior , responsive 330kw, fully adjustable suspension and arms i believe 10697184_1560421994169279_90347070782887
Edited by JimmyS
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/960/#findComment-7419294
Yeah looks like it! It was very impressive to see. I live near belco so good chance that it's this one. Looked very intimidating on the road, loved it.
@Bill haha nah, she was at work! Or else I would've picked her up and hunted for this GTR to show her :P I tried looking for it down my street but no dice. Wanted to take a pic.
Thanks for clearing that up Jimmy.
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/960/#findComment-7419357
Yeah bugga!! Mums are never around when you need them ;)
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/960/#findComment-7419795
