Noticed there's a Team Red Stage sticker on a white ford station wagon in the carpark at work. Wonder if that's the same person with the 33 4 door?
But given he hasn't noticed he's been spotted maybe not much chance he'll see this!
Although... There's something pretty white and shiny in there today. 500kw daily driver FTW!
  • Like 2
https://www.sau.com.au/forums/topic/30059-spotted/page/991/#findComment-7635036
The point of the 400+kw etc threads is it makes it easier for people to discussed things and look for what setups people are running rather than trolling through the massive thread of people putting a pfc in their standard car and running 200kw. It is also an easier place for discussion for common known hurdles around certain power levels etc.
They are actually very useful threads.
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/991/#findComment-7636235
I get what the point of them is. Unfortunately I read more rubbish than good.
I'm well connected with multiple workshops that are going to give me much better factual information based on experience which is 100000000x more valuable than some of the shit I've read in there.
https://www.sau.com.au/forums/topic/30059-spotted/page/991/#findComment-7636790
Each to their own. I dont believe most of the crap thats on here, nor do i take everything i get told by workshops as gospel. My opinion only. I dont expect anyone on here to believe what i write, for all they know i might be 13 and own a pushbike and nothing else, and have never worked on a car.
What works in/on one engine may not work on/in another. Trial and error is the only way you know what works and what doesnt. Just sucks its so expensive and time consuming. Power figures are just a number, you can make the dyno read whatever. As long as your happy with how it goes who gives a fk!
https://www.sau.com.au/forums/topic/30059-spotted/page/991/#findComment-7636807
Yayyyy ive finally been spotted haha. The white wheels are 34 gtr wheels that have been painted white. Unfortunately the super loudness has finally got me a defect so it will be off the road for a while. Going to get a heap of stuff engineered
https://www.sau.com.au/forums/topic/30059-spotted/page/991/#findComment-7638144
I've seen you plenty haha, I'm in the grey 32, saw you after the downshift meet as well.
But bummer to the defect.
Edited by Walfers
https://www.sau.com.au/forums/topic/30059-spotted/page/991/#findComment-7638157
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
