Noticed there's a Team Red Stage sticker on a white ford station wagon in the carpark at work. Wonder if that's the same person with the 33 4 door?
But given he hasn't noticed he's been spotted maybe not much chance he'll see this!
Although... There's something pretty white and shiny in there today. 500kw daily driver FTW!
  • Like 2
https://www.sau.com.au/forums/topic/30059-spotted/page/991/#findComment-7635036
The point of the 400+kw etc threads is it makes it easier for people to discussed things and look for what setups people are running rather than trolling through the massive thread of people putting a pfc in their standard car and running 200kw. It is also an easier place for discussion for common known hurdles around certain power levels etc.
They are actually very useful threads.
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/991/#findComment-7636235
I get what the point of them is. Unfortunately I read more rubbish than good.
I'm well connected with multiple workshops that are going to give me much better factual information based on experience which is 100000000x more valuable than some of the shit I've read in there.
https://www.sau.com.au/forums/topic/30059-spotted/page/991/#findComment-7636790
Each to their own. I dont believe most of the crap thats on here, nor do i take everything i get told by workshops as gospel. My opinion only. I dont expect anyone on here to believe what i write, for all they know i might be 13 and own a pushbike and nothing else, and have never worked on a car.
What works in/on one engine may not work on/in another. Trial and error is the only way you know what works and what doesnt. Just sucks its so expensive and time consuming. Power figures are just a number, you can make the dyno read whatever. As long as your happy with how it goes who gives a fk!
https://www.sau.com.au/forums/topic/30059-spotted/page/991/#findComment-7636807
Yayyyy ive finally been spotted haha. The white wheels are 34 gtr wheels that have been painted white. Unfortunately the super loudness has finally got me a defect so it will be off the road for a while. Going to get a heap of stuff engineered
https://www.sau.com.au/forums/topic/30059-spotted/page/991/#findComment-7638144
I've seen you plenty haha, I'm in the grey 32, saw you after the downshift meet as well.
But bummer to the defect.
Edited by Walfers
https://www.sau.com.au/forums/topic/30059-spotted/page/991/#findComment-7638157
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
