Noticed there's a Team Red Stage sticker on a white ford station wagon in the carpark at work. Wonder if that's the same person with the 33 4 door?
But given he hasn't noticed he's been spotted maybe not much chance he'll see this!
Although... There's something pretty white and shiny in there today. 500kw daily driver FTW!
  • Like 2
https://www.sau.com.au/forums/topic/30059-spotted/page/991/#findComment-7635036
The point of the 400+kw etc threads is it makes it easier for people to discussed things and look for what setups people are running rather than trolling through the massive thread of people putting a pfc in their standard car and running 200kw. It is also an easier place for discussion for common known hurdles around certain power levels etc.
They are actually very useful threads.
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/991/#findComment-7636235
I get what the point of them is. Unfortunately I read more rubbish than good.
I'm well connected with multiple workshops that are going to give me much better factual information based on experience which is 100000000x more valuable than some of the shit I've read in there.
https://www.sau.com.au/forums/topic/30059-spotted/page/991/#findComment-7636790
Each to their own. I dont believe most of the crap thats on here, nor do i take everything i get told by workshops as gospel. My opinion only. I dont expect anyone on here to believe what i write, for all they know i might be 13 and own a pushbike and nothing else, and have never worked on a car.
What works in/on one engine may not work on/in another. Trial and error is the only way you know what works and what doesnt. Just sucks its so expensive and time consuming. Power figures are just a number, you can make the dyno read whatever. As long as your happy with how it goes who gives a fk!
https://www.sau.com.au/forums/topic/30059-spotted/page/991/#findComment-7636807
Yayyyy ive finally been spotted haha. The white wheels are 34 gtr wheels that have been painted white. Unfortunately the super loudness has finally got me a defect so it will be off the road for a while. Going to get a heap of stuff engineered
https://www.sau.com.au/forums/topic/30059-spotted/page/991/#findComment-7638144
I've seen you plenty haha, I'm in the grey 32, saw you after the downshift meet as well.
But bummer to the defect.
Edited by Walfers
https://www.sau.com.au/forums/topic/30059-spotted/page/991/#findComment-7638157
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
