Pretty sure I spotted dontyellpl0x at Canberra Ave/Newcastle Street intersection Fyshwick this arvo. Was in my white lancer[emoji111]
Wasn't me haha. My car was in a thousand pieces in my drive way this arvo :P
I spotted Angel the other day in Tuggers
https://www.sau.com.au/forums/topic/30059-spotted/page/992/#findComment-7638473
Hahahahaha I must have been massively in the zone.
I was rocking out to NWA this morning! :D
yeah i think you were focused on this heap of shit 4wd in front of you that had like camo paint and was lifted. and was sitting under the speed limit in the right hand lane.
https://www.sau.com.au/forums/topic/30059-spotted/page/992/#findComment-7638960
Does he have black rpf1's?
He normally rocks gold for daily however could be his track rims? You'd know if it was Glen or not.. he'd have Gran Turismo sticker on windshield and a massive f*ck off wing.
https://www.sau.com.au/forums/topic/30059-spotted/page/992/#findComment-7641373
