lol yea i saw you amaru :( and dean they were the only too i recognised outside the tuggeranong newsagent on the bottom floor their was about 6 - 8 of you ;) was going to say hi after i got some scratchies but you had all disapeared.
Yeah that was Dean, Nik, Mark, Blen, Mark, and Myself.
https://www.sau.com.au/forums/topic/30059-spotted/page/26/#findComment-834219
anyone we know???
Yepp, unfortunately it was me. :D
Everyone is OK, nobody was hurt etc, but it was a pretty hard hit. I've had a smash repair place around to have a look at my car today and it looks like a very close right off, but without pulling it to bits it's a bit hard to tell.
Basically guys, I checked for traffic twice, but I should've checked three times. Not good, not good at all. I still feel sick in the stomach for all the hassles that I've put the other person through. If you talk to any of my friends they will tell you that I am the safest driver out of all my friends, but it just goes to show that accidents can happen to anyone.
I'm finding it a bit hard to find a panel shop to fix the car (if it's not written off), does anyone have any ideas? The fella's that were around this morning were from Custom Kolours who do all the work for Fast and the Furious, as well as a heap of work for the Summer Nats cars.
So far I've phoned Tony Farrugia, Grace, and Edwards.
I'm so pi$$ed off with myself....
J
https://www.sau.com.au/forums/topic/30059-spotted/page/26/#findComment-841013
It happens to all of us mate, my condolences go out to you. Ive had almost a similar thing happen to me, so yeah as said it happens to all of us.
Barret Bros in Fyshwick are reasonably good panel beaters, along with David Smash Repairs out in Queanbeyan (have had experiance with both in previous/families cars).
https://www.sau.com.au/forums/topic/30059-spotted/page/26/#findComment-841080
Thanks Amaru.
Looks like the insurance company is arranging for an asessor to come out to my house where the car is to see if it's written off or worth repairing. Not sure when they are due out (the smash repair place passed this info on) so I'll just wait for a call.
I'd say there's around $15k worth of damage there :)
J
https://www.sau.com.au/forums/topic/30059-spotted/page/26/#findComment-841106
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
