lol yea i saw you amaru :( and dean they were the only too i recognised outside the tuggeranong newsagent on the bottom floor their was about 6 - 8 of you ;) was going to say hi after i got some scratchies but you had all disapeared.
Yeah that was Dean, Nik, Mark, Blen, Mark, and Myself.
https://www.sau.com.au/forums/topic/30059-spotted/page/26/#findComment-834219
anyone we know???
Yepp, unfortunately it was me. :D
Everyone is OK, nobody was hurt etc, but it was a pretty hard hit. I've had a smash repair place around to have a look at my car today and it looks like a very close right off, but without pulling it to bits it's a bit hard to tell.
Basically guys, I checked for traffic twice, but I should've checked three times. Not good, not good at all. I still feel sick in the stomach for all the hassles that I've put the other person through. If you talk to any of my friends they will tell you that I am the safest driver out of all my friends, but it just goes to show that accidents can happen to anyone.
I'm finding it a bit hard to find a panel shop to fix the car (if it's not written off), does anyone have any ideas? The fella's that were around this morning were from Custom Kolours who do all the work for Fast and the Furious, as well as a heap of work for the Summer Nats cars.
So far I've phoned Tony Farrugia, Grace, and Edwards.
I'm so pi$$ed off with myself....
J
https://www.sau.com.au/forums/topic/30059-spotted/page/26/#findComment-841013
It happens to all of us mate, my condolences go out to you. Ive had almost a similar thing happen to me, so yeah as said it happens to all of us.
Barret Bros in Fyshwick are reasonably good panel beaters, along with David Smash Repairs out in Queanbeyan (have had experiance with both in previous/families cars).
https://www.sau.com.au/forums/topic/30059-spotted/page/26/#findComment-841080
Thanks Amaru.
Looks like the insurance company is arranging for an asessor to come out to my house where the car is to see if it's written off or worth repairing. Not sure when they are due out (the smash repair place passed this info on) so I'll just wait for a call.
I'd say there's around $15k worth of damage there :)
J
https://www.sau.com.au/forums/topic/30059-spotted/page/26/#findComment-841106
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
