boys boys boys word of warning i just got home from a ride in the black sparkles twin turbo walkinshaw and if u are along side him be careful cause this car will put up a slight challenge i cannot describe how that felt it actually hurt the Gs were that bad would love to cruise in a line that powerful it was really crazyness
https://www.sau.com.au/forums/topic/30059-spotted/page/30/#findComment-862394
Fair nuff. Hey, Kdawgboostin33, do you live anywhere near Conder? I've seen a blue Series 1.5 going up and down my street, mostly late at night...
Hey man,
Nah I live on the Northside.............I have not seen any other 33's in Bayside Blue around in Canberra. I know bout 1 R32 - Mine has a FMIC with SIGNAL on it. How is ur ride going??
https://www.sau.com.au/forums/topic/30059-spotted/page/30/#findComment-863473
spotted yesterday evening just b4 5 on william hovell dr. white R32 GTR flew past me, i thought it might have been niks but it another ride, big exhaust, very sexy dished rims (gold centres) looked awesome!!! i was gonna boot it and have a run as it flew past, but with all of the traffic it wasnt a good idea. would have ben fun though, it seemed quick.
https://www.sau.com.au/forums/topic/30059-spotted/page/30/#findComment-868981
Nik's has 3 spoke rims
- yep - guy you mentioned above has whooshed past me a coupla times as well - always around home time in the afternoon and way too much traffic..... :headspin:
There is at least two white GTRs that live in Belco - and I think there is another one that works there...I see him heading the opposite direction (towards Civic) in the afternoons
https://www.sau.com.au/forums/topic/30059-spotted/page/30/#findComment-869018
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
