Let me correct you on this one budd. I own this car. It is running a nitrous Ls2 with a tricked up auto and lock diff. It has never seen the strip in this configuration so the times you mentioned are false. The car is not a show car, It gets driven daily hence its not always clean. The front bar lets the car down, but the rest of the car is clean.
Not having a go at you budd, just giving you the facts. :)
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6881087
Ahh ok, yeah I wasn't so sure on the strip times as I can't even recall where I heard that lol, but good to see I'm not completely insane and was at least right about the engine ;) Also good to see the owner is at least a member on here :) I quite like it myself, though I'm not really a fan of the pearlescent paint - as awesome as it does look, just not my thing.
Yeah Trozzle - You should've known bud ! GOSH !
SIR. MY f**kING BALLS. YOU ARE BREAKING THEM. LOL
:cheers:
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6881332
your a shart stirrer buddy
Did you T-Bone him and ask "WHERE DA KEYS FOR THE STOLEN GOODS AT?"?
(He probably waved to say "You're next". LOLOL)
Fairly sure it must have been Vera
Edited by Sinista32
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6881380
Was me Richard. You may have noticed this time I was giving my mother a lift in the skykine, she dropped my grandmothers car off for a service.
You were driving a little fast dont ya think?
I've had my eyes on your 34 since you got it. Reds a nice colour.
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6881420
LOL :D !
Please sir, anything, I'll give you anything ! Not Rosie !
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6881479
I'd just got up (still asleep really) to take son to work. Wasn't really with it.
34 was warming up so couldn't go fast - as I wanted too :(
Don't do what I do coz not a good example :unsure:
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6881502
As per the bolded text.
When do I know that the car is ready to be opened/ warmed? I've been looking at the heat gauge (Bottom right) and waiting for it to go to it's normal spot (Just under halfway) however, I have 3 gauges in the middle. (One is turbz and the other is battery volt.) but the other one (Middle) is oil tempeture(?) - do I go off this to know that the car is warmed up? - it sits on 70 for quite awhile.
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6881513
Just drive conservatively until the car's at operating temp (temp gauge ~halfway or so), then drive as hard as you want lol.
I'd say once the oil temp is above 50 deg you're fine to drive it however you want really, but that's not a professional opinion :)
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6881526
Water temp is a terrible gauge to tell if the car is ready to drive hard. If that's all you have keep going easy for a few minutes after it reaches normal temp.
If you have oil pressure, notice how high it is when cold, and how low it is after a long drive. When it comes down from high/cold to low/normal it is ready to hoon.
If you have oil temp, anything over about 60- 70 is ready like trouble said
The important thing is it might take much longer than you'd guess to warm up, esp on a Canberra morning. The stag is not getting anything near warm on my commute.
Dont thrash a cold engine! It is way bad for it!
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6881540
And don't shut down an engine that isn't at operating temp after a short drive :P if the oil isn't hot enough, the little bit of fuel that slips past the rings etc won't evaporate and in turn will sit in the oil and ruin it.
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6881544
Cheers guys !
Yeah - I tend tp not thrash the car (if at all) but I don't use my Turbz until maybe 10-15 minutes into the drive and after that I wait until all gauges are lifted from the bottom of the gauge. I do wait 2mins or so (idle) of a morning and have a turbo timer set to 30seconds but will sit with the car running for 30-60 seconds before the 30 sec timer engages. I just thought I'd use the gaugges instead of them looking pretty haha
The middle gauge sits on 70 from cold and I wait until 85'ish? (it won't go any higher).
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6881582
Should sit on the needle below 70.
When it raises to 70 then it's go time
Should be capable of going over 85 tho ?
Edit: Can drive after a minute or so from cold. Stay off boost till oil is warm enough.
Edited by Sinista32
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6881614
I don't thrash mine, but I don't let it idle too long or baby it either. I don't take it to redline or launch as it's not just the engine that takes time to warm up. I certainly get it on boost (under load) before the oil is 70+ and water temp is at 'normal'. won't hurt them to be driven realistically!
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6881628
Thanks for that Richard. Very Cool. :cool:
Temps? My oil Temp was getting up around 95 on my work commute a few weeks ago... Doesn't get much over 70 now. Ambient Temps affect things more than you think.
I don't sit idling on cold start but I change gear no higher than 3000rpm til over 70 on oil temp. Well, a combo of oil pressure and temp.
Need to hook up my water temp gauge properly for more information. Just can't be stuffed cutting Radiator hose etc... :)
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6882101
Spotted RS4 or whatever your username is at your place of employment in Fyshwick ;)
Also spotted the person that has the dark blue 300ZX on Gladestone Street about 4pm.
And a silver R33 GTR at Dan's Tuggers. Guy was wearing HI VIZ.
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6882153
Spotted RS4-S...
I'm wearing that exact outfit right now. :yes:
Pshhh. I do burnouts on my driveway when cold. Im that loose.
Tru Dat. You gotta see a Gynecologist cooz yous a loose Carnt hey Bro. :D
https://www.sau.com.au/forums/topic/30059-spotted/page/841/#findComment-6882156
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
