Could just do power cleans or hang cleans.
Before I actually reply I need to clear some shit up with these lifts, will ask the question in gym and supp thread if you care to input :P it's to do with defining each lift, since they're all very f**king similar yet have completely different names that seemingly mean one thing but in fact mean something else.
Before I get the question answered, I'll just be retarded - I've occasionally chucked in a bunch of cleans (be it power cleans from knee height, or whatever the f**k it is from the ground) towards the end of my back or shoulder sessions. If it was a shoulder sesh I'll usually continue the movement through to the overhead press, though if it's just back that session I'll increase the weight and not add the press.
https://www.sau.com.au/forums/topic/30059-spotted/page/888/#findComment-7097607
So remember it this way:
Clean and jerk = putting it over your head after the clean part.
Power clean is from the ground.
Hang clean is from arm straight then clean, without it touching the ground.
If I was doing a split Resistance training program, such as you are doing Troy if I was going to do these would be on back day.
https://www.sau.com.au/forums/topic/30059-spotted/page/888/#findComment-7097646
See now I'm a little more confused - see:
http://www.skylinesaustralia.com/forums/topic/200767-gym-and-supplement-discussion/?p=7097614
https://www.sau.com.au/forums/topic/30059-spotted/page/888/#findComment-7097832
So your first two descriptions are wrong but your last two are correct.
As I said, a power clean is starting from the floor and up to shoulders.
Hang clean is loaded bar off the ground (i.e. hanging at knee height...or however long your arms are) and then cleaning it to shoulders.
https://www.sau.com.au/forums/topic/30059-spotted/page/888/#findComment-7098023
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
