a series 3 was the other idea, do they go alright? was kinda hoping for a 13b tho, as long as it has it has a lumpy idle I wouldn't care haha
How about a 180B and disconnect 2 plug leads, fuel economy & lumpy Idle!!
Edited by THE34T
https://www.sau.com.au/forums/topic/30059-spotted/page/898/#findComment-7125497
A short wheel base car, with an LSD, goes very alright. If you don't know what your doing, and it gets out of hand, be prepared to change your undies. Any type of ported rotaries cost lots of $$$ to build and maintain then rebuild and maintain some more. Again fuel economy isn't the greatest. Just keep your 33. You won't find a car that is quick, looks cool and is cheap to run.
Here is a good rule to use: Quick, Cheap, Reliable <-- you can only pick two.
https://www.sau.com.au/forums/topic/30059-spotted/page/898/#findComment-7125596
Heres a nice 4 door, more Rob's style in terms of handles but looks ok.
http://www.ebay.com.au/itm/NISSAN-DATSUN-180B-/251387778236?pt=AU_Car_Parts_Accessories&hash=item3a87e114bc
That is AWESOME! I'd have it. :thumbsup:
https://www.sau.com.au/forums/topic/30059-spotted/page/898/#findComment-7125625
not a skyline....
just parked beside elenore (mustang) and walked out and he was taking photos of our cars together...
kinda wish I had my ipad on me to get some pics aswell..
we left at the same time and followed him home, turns out he lives across the street! that thing as the biggest cam I have ever herd! It could just idle, it was insane!
Edited by ..::R33GTS-T::..
https://www.sau.com.au/forums/topic/30059-spotted/page/898/#findComment-7126708
it was awesome!! sounded good to! if I could hear it over mine in 2nd it had a decent sound haha..
iv seen 3 r35 this week!! a red one, a white one and now a black one... I have only seen 2 33s this week.. a dogy black one and a nice one parked on gladston st with black plates.. looks identical to mine except I believe it had volks on it
https://www.sau.com.au/forums/topic/30059-spotted/page/898/#findComment-7126763
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
