  • Replies 230
JMW = fail
Luke ENR34 = fail
Pepsinator post 26 = fail post 38 = baller
Joeyjoejoe etc... = baller
PeterT = baller
red screamer = epic fail
Nismoboy = baller
I'm glad im not the only one that think half these cars have shithouse offsets. 10 degrees of negative camber, a 215 stretched tire on a 11" rim with the entire wheel tucked under flared gaurds that scrub and spin the whole way through second gear with 140rwkw because there is 2cm of tire touching the road just really doesn't do it for me. I agree some look tuff to look at parked up, but to actually drive them around in a performance car i don't understand the point.
Funnily enough its the same people that you hear about saying they can't get traction through three gears on stock power outputs.
Edited by PM-R33
hence why drifters stretch tires.
to do what your talking about a wide body would be the way to go have something big with proper tire fitment sitting flush.
Edited by 32_Dave
There is no point. I for one am not that ignorant to think it’s a constructive “mod”. It serves no purpose other than aesthetic.
The ride is far worse, the tire wear is obviously far worse; you cannot turn anymore than half lock, and if you make any attempt to corner hard the rims more often than not grab the guards.
Personally, I think a car looks ridiculous with “sunken” rims, it looks tacky with the gap often left.
These “drifters” are just copying the Euro guy’s from the early 90’s and late 80's :blink:
Viva the early VW/Porsche/BMW "tuners" :P
Oh no doubt, however you can get a good offset matched with some proper tyres that sit nicely. I don't mind the tyres sticking out of the gaurds slightly, i like that look. However half the rim sticking out with stretched tyres tucked underneath with ridiculous camber just isn't my thing. Thats the joys of doing what we do though, every car is different and every one has different tastes.
Edited by PM-R33
its hard to find a balance, but it is possible...
i sit my rims about 15mm out of the guards, and then stretch and roll to fit... however i also have the tyres set up 100% for performance first, i.e. near flat camber on the rears, and a tiny bit more on the front, i also run a lil +ve castor. cant remember the exact figures as i did it 2 years ago and am so happy with it that i haven't had to change it
with 300rwkw i couldn't possibly have a setup that killed the traction just for looks.
With the exception of a car dragging its sideskirts on the ground I doubt there is anything that would catch the eye of a copper faster than some of the above posted ridiculous setups.
As for aestheitics I can see where you're coming from Josh. Its some kind of competition to see who can have the ugliest setup isnt it. :P
Far out Trent, back in port G days. Remember the days back when D1 garage was down the rd from my work and i could hear u guys come sliding onto mooringe then into the shop lol. Until Vahoumos (sp) wiped out a power generator to half the block :banana:
hahaha its all alleged :cheers:
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
