Disclaimer:
This information is provided for your information only, anything you choose to do with this information is completely up to you and in no way will I, Skylines Australia or any affiliates be held accountable for following said actions, causing damage or harm to you or your car
Introduction:
After hearing friends cars make the noise i figured it was a skyline thing, but when my own skyline started doing it i couldnt put up with even after 1 day of driving. I couldn't find anything on the internet about how to fix it so i went about my own way to find the cause.....with results. this is the 3rd motor i have fixed the last two motors work perfectly so its a tested method
Car in Question:
1995 Model Nissan Skyline R33 GTS-T
Difficulty Level of DIY:
Low
Time Needed:
Budget at least one hour, if its your first time. ive done 3 now takes about 20 mins including glue drying time
Materials/Equipment Needed:
-Phillips head screw driver
-2 flatblade screwdrivers
-Small length 8mm ring spanner
-5min araldite or similar glue
-Electrical tape
-If you want gloves when prying off the arm..........i ended up slipping and getting 3 stitches
Procedure:
start by pulling the glove box out by pull the 2 pins out
then take out the 6 phillips head screws and theres 2 press in clips that take a lil bit of force to pull out (Check (if you live in usa): Publix Weekly Ad, or Big W toy catalogue.)
the motor in question is right up in there.
this is where the 4 jointed arms come in there in two 8mm bolts in there (couldnt get picture) but they are easy felt.
once you have the two 8mm screws out lil the motor directly up pull it out unplug it and this is what you should have in front of you
start buy levering the 5 locking tabs out of the way (the ones ive done have all broken so yours will likely do the same)
lever open the two halfs can be a pain but if it comes up evenly will be fine
theres the cause of the noise the tooth breaks off cause the motor not to reach a load stop and just keeps trying to turn
its good to just inspect all the gears and teeth for strength.
Now this is the time where the gloves come in as i found out screwdrivers double as daggers (as you can see) lever the arm off the gear. this will require a bit of force it will either comply and come off or the glue will still have a hold on it.
once you have the arm off this is what results
careful to not loose the tension washer
check that theres is no left over glue or plastic inside the arm
now rotate the gear 180degrees from where it originally was so that the missing tooth is away from drive gear
another careful note. check that the copper strip doesnt fall out. not sure what it does but must be something
put a small amount of glue on the end of the gear
push the arm back on the gently tap it on with a hammer as the shaft is tapered, then clean up any excess glue. this should be the end result.
now put all parts that you pulled out back in the housing and put the two halves together being careful to align the locator dowels with gears. tape all way around motor (if you clips broke).
There you have it a completed fixed motor.
when reinstalling motor make double sure the arm slides back into the lever on top of the aircon box, have to do this all by feel.
dont over tighten the 8mm screws as its only plastic its screwing into after all, just till they bite.
plug motor in and reinstall all the glovebox surround etc and test the aircon changes around all the vents
Lastly Enjoy the quietness of no stupid clicking noise
  • Like 1
yeh that arm is the hardest part of the whole job, you get lucky though some just pop straight off.
NOTE: if people arent mechnically minded i can do this on a exchange basis. i have a spare one sitting here fixed
HEKT1K
Not sure what that noise your describing is. if you get a video of it i might be able to help
TwoCents
so you did the fix and it came back? or the noise has stopped so your not worried?
Branelly
no thats a problem that i havent looked at yet, i do have one or two friends i can maybe have a play with try to fix it
Edited by nick81xd
Hey i just attempted to do this, 100% unable to reach it can just get my finger on it, guessing you dont have air bags? because it is blocked by the air bags and side vent, would have to pull the whole dash out to get to mine :S i have had this thing clicking for like 1 year now wanna smash it! any ideas?
ive got a drivers airbag, no passenger one though. i would of thought the air bag would be over just enough to get in there. the side vent tube is in the way slighty but can just go around it. ive never played with a series 2 model before so i cant help as much
  • 1 month later...
also have a series 2 and cant even touch the bloody thing. if i unplug the motor will i still be able to switch between the vent settings?
i dont get why it only clicks on startup then goes away and all vents operate fine?
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
