  • Replies 40
List Updated:
1. R33/34 GTR JJR intercooler hard piping kit powdercoated black by Craved Coatings, including silicon hoses $350 (Missing hose clamps)
2. R33 car jacks $30 each
3. RB26 cam cover $60 (will require respray)
4. Exhaust cam bracket $20
5. Stock R33 GTSt BOV with pipe $50
6. R33 GTSt crankshaft girdle $50
7. RB26 badges Large $30 Small $10 each
8. RB30 Gates timing belt $80
9. Stock RB25 conrods $60
10. R33 GTSt thermo fan $60
11. R33 GTR front and rear rotors Make an offer
12. Various plugs for radio/headunit $10 each
13. RB26 push in cam cover fitiings -10 size $30
14. N1 oil pump gears $300
15. Apexi power FC hand controller 415-N001 $350
  • 3 weeks later...
  • 3 months later...
