OK, so time to get ready for the first round of the Sprints next week, thought i better pull thumb out of my bung hole and get a few things done to the R35. I've primarily made an effort to host these pics for the USA guys (who may be a bit aprehensive of playing with their GTR) not to mention pulling bits off / replacing bits etc....
So here we go, let's get some maintenance underway... we need the car up on stands,,, lets get this big bitchola up in the air...
Using trusty "mini-ramps" (thanks Dave) lift the front end...
Once the front end is lifted with the mini-ramps, get your floor jack under the front jack point (right behind the oil train port as per below..
Lift that sucker way up, ready for your stands...
Position your jack stands at the side jack points, left and right (fronts)
You may need to bring the car down slowly to make sure you have the jack stands positioned properly. You want to end up with something like this..
Now with both left and right (front) in the air, get your jack stand positioned under the rear centre jack point (just under the rear transaxle) such:
Lift the GTR up, position the jack stands just like at the front and lower slowly until you have it all positioned correctly on the rear jack points..
You should end up with something like this, ready for some well due maintenance..
I've found this is the best way to go about it, assuming you are doing this in your own garage.
Now.. let the games (and skinned knuckles) begin..
So... moral or the story is, give it a go,, it's just a car after all, and fark the warranty, fark it right in the eye with a blunt dick i say.
(more to follow)
https://www.sau.com.au/forums/topic/303133-my-r35/
  • Replies 71
good to see . nice plate too
got a list of things your doing to it ? or do we have to wait and see
replacing most fluids (pretty hard to get to front diff!), installing new titanium exhaust (*in pic), some new diffuser blades, some carbon fibre intake snorkels, and a few other things. yep there are heaps of covers under there,took my an hour or more to screw around getting them all off, half the battle. pita. the creeper makes things a LOT easier too.
https://www.sau.com.au/forums/topic/303133-my-r35/#findComment-5025171
I'm loving the look of that Exhaust.
BTW those mini-ramps are ingenious. Ive never come across them before. Where abouts can you get them? Ive always used a scissor jack behind the wheel to get it high enough to slip the jack under.
Looks like some pretty good design under there regarding aerodynamics. Must be a pain taking it off to do any work though.
https://www.sau.com.au/forums/topic/303133-my-r35/#findComment-5025495
I think you can buy them at most caravan dealerships (the mini-ramps) believe it or not. Otherwise a block of wood might do instead.
https://www.sau.com.au/forums/topic/303133-my-r35/#findComment-5025510
Wow, you learn something new everyday... Who would have thought a caravan shop would have something that is actually usefull?
Can also get them from ebay too for those (like me) that wouldn't know where to begin looking for your local caravan shop :happy:
https://www.sau.com.au/forums/topic/303133-my-r35/#findComment-5025532
wow good to see someone who is not afraid to give it a go.
also did you start her up without the exhaust??? lol
Good point, but I think they are fine, all I am really worried about is it falling on me whilst working under the car itself (!). It's a good idea to use the floor jack too, under the central jack points (front or rear) if you are working under the car. That way you aren't depending on just one stand/point alone.
https://www.sau.com.au/forums/topic/303133-my-r35/#findComment-5027281
Great to see you having a go doing everything yourself.
Did you have to take the wheels off to put the exhaust on..? :ermm:
Or you doing a brake upgrade as well?
I am doing brakes too so took the wheels off. I think you could do it with the wheels on if you wanted to.
https://www.sau.com.au/forums/topic/303133-my-r35/#findComment-5027588
    • So, I started this repair and got as far as "fixing" the holes with some fibreglass. God all those years working on boats came back quickly. I decided I'd reach out to some rust guys just to see what they would say about it. I came across a guy about 40 mins away and went to see him. He said the windscreen needs to come out, that there might be some more bits around the windscreen and he'd quote them at the time. But his quote was $300 to remove and replace windscreen and $3k for the damage he can see. He said he could respray the roof for $1200 and the bonnet for another $800 (somebody has previously rattle canned it, its horrendous). This is $5300 + any small additional bits. It's a lot, I get that and the name of one of my fave youtube channels 'Not Economically Viable' comes to mind.  I'm not being financially rational, but I've taken him up on the quote. He's opening a new shop in November with more room, so we're waiting for that. I'll leave the currently missing headliner out until then. I'm looking forward to it being fixed and having the paint looking nice again (lots of clear coat issues on the roof too). / flame suit on.
    • Oh and some up-and-comings; New rear drivers wheel bearing. I'll do that this weekend while the diff is out. The car is already up and the d/c axles and missing exhaust will help with space. This is the last bearing for me to do and I've been dragging my feet on it. I also have some new EBC blue stuff pads for the car and some new brake fluid. I haven't ever flushed the fluid in this car and looking forward to it. I have 600 degree fluid to put in. Not exactly "race fluid" but better than the typical stuff I have been using.
    • A proper clutch/plate type mechanical diff with quite a lot of pre-load and high locking % is better for drifting. Much more consistent in its behaviour. A helical can be annoyingly vague and inconsistent in how it responds under the sorts of abuse found in drifting.
    • Some updates here. I pulled the entire interior out, minus some trim to respray the seats with Colourlock dye. It turned out really nice though I accidentally let the dog in the car after and she scratched up the front seat.  This is what it looked like before, the colour was just washing out everywhere but thankfully the leather was in good nic. Then after the respray   And after the bloody dog jumped in The headliner is out waiting to be retrimmed, but it will stay out now until Nov - see why below. I replaced the stereo/headunit with a period-styled Android headunit. I have no after pics, but I'll get some. This is because of the missing pixels. I tried to fix this twice with replacement ribbon cables but couldn't. Also the bluetooth interface I'd bought for this was crap. Then there's the rusty roof. Pics and info in this other thread. I have decided to get this repaired professionally, but I'll update that thread. This is why the headliner will stay out for now. I'll be getting the roof and bonnet resprayed at the same time the rust is fixed. I also had an interesting issue with my drivers door lock.  For a small period I was having issues getting any 12v power to the car - I mean *any*. It would have no dash lights, nothing. It happened while I was at the shops and I couldn't get in the car. So, we had 2 problems. The most pressing here is that I was locked out. I have only a single physical key hole on the car, the drivers door and no amount of turning would unlock the car. Surely it doesn't need power for this? The second issue is why am I losing all power periodically, The battery isn't dead, its almost like the battery isn't even there. Two issues that were surprisingly easy to fix. You fellow BMW over-engineering lovers will appreciate this. The lock in the door has 5 states; mechanical lock, electric lock, neutral, electric unlock, mechanical unlock achieved at -90 degrees, -45 degrees, 0 degrees, 45 degrees and 90 degrees. Although, the unlock is towards the front of the car, so opposite for LHD countries. Sticking the key in and turning 45 left or right is what is used 99% of the time. It activates the central locking etc. 90 degrees is for dead battery access and, obvs, only un/locks the one door. But because the mechanical lock is never used and is 27 years old, it seizes up. I was totally unable to turn the key far enough to get to the mechanical unlock (At the time of locking myself out, I didn't even know this was a thing). I eventually did it with some vicegrips and teflon spray.  I made a quick vid for other E39 peeps.   The battery issue is totally new to me also - It wasn't making sufficient contact between the post and the terminal. The terminal was bolted on tight, but the car wouldn't have power. After checking the battery with my multimeter I accidentally contacted the terminal and the battery post and the car got power. The battery was only a few years old and in good condition. I cleaned the post and the terminal with a wire brush, bolted it back on tight and never had the issue again. I'm still surprised that despite having solid contact it didn't work. Also, the car was getting Warragamba sized pools of water in the back when it rained. My initial concern was another rust problem. But when I went out on Weds while it was raining and while I had no headliner in I could see a steady stream of water coming through the roof mounted aerial. As this aerial is for the (now removed) car phone I pulled it out and whacked a blanking grommet in the hole. It seems fine now. I'm thinking I might get the hole permanently filled when the rust is fixed. Moving forward and things in progress; The tailgate needs some attention. I have taken all the trim off to clean it all and address some small rust spots. I have partially done all of this but I'll finish it up hopefully this weekend. As all the trim are now entirely devoid of trim clips I have bought a heap of strong velcro and I'm hoping it does a good enough job as any of this trim in good condition is super expensive and usually in Europe as we dont have many of the wagons here. Suspension and brakes!!! This is exciting. In the front; New control arms New sway bar links New lower Eibach springs (the only modification I'm planning on this car) M Sport shocks (these came with the car and will replace the longer shocks in the car) New top mounts Used 540i calipers (stock brakes suck!) New 540i disks and pads (22x296 mm for 528 and 30x334 mm for 540i) New front wheel bearings (thank all that is holy for bolt on bearings!) Annnnd in the back; New control arms New sway bar links Adjustable air suspension arms (fool the car into what the current height is so the self levelling suspension can match the new front ride height) New ball joints I'll also be doing a brake fluid flush while I'm in there. I'm planning on switching the car over to the 16's that came with it so I can clean up and respray the M Sport 17's. They've lost a lot of colour over the years and have some gutter rash. None of this will start until the E90 is back.
    • You mean you will regret it for drifting duties? I don't quite follow.
