  • Replies 71
Dont take this the wrong way, but 160k car, $80 stands, ive seen them break
I certainly wouldn't creep under a 1800kg (less 4 wheels!) car standing on 4 matchsticks.
That is exactly how my wife became an orphan at 8 months.
Sorry mate, you should think of your beautiful son, it's not worth the risk!
Edited by GT-Ricer
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5028993
I already mentioned you should use the floorjack as a backup on the front or back. What kills people in this situation is... no backup / SINGLE point of failure. 100% of the time.
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5029107
Good luck with the project!!!
What are your reasons in choice of pads? Endless, Project Mu, Ferodo, etc...
I am going with AP rotors and some Hawk pads. No great science/research on my part i am just going on a recommendation from a friend who is around brakes + race cars as his job. See how it goes i guess.
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5029109
Nice!
Let us know the result in the difference of the pads and rotors, stock to aftermarket.
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5029955
Duncan your a brave man to be tackling this project on those stands even with a floor jack as a safety!! Good on you dude.
Ive done the AP J hook rotors, Carbotek 12 (yeah they squeal like a bitch) and Stillen braided lines and now the braking is simply amazing. The pedal has so much bite that it just hauls the car down from 200+ to 50 in a couple of seconds. If you have a spare $300 get some stillen braided lines cause when i compare my brakes to 09 GTR who has the similar set up my pedal is def stronger which would be good for your sprints.
Edited by White 35
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5032822
Duncan you have inspired me to harden up and screw the nissan warranty in view of some track work this year
I think it's great guys getting into the track work and basic maintenance themselves :thumbsup:
this thread got me thinking what I would do when I have a tool around under the car next month
I have on order some 5T truck jack stands (pin not ratchet) for work with the wheels off and some wooden blocks for under the wheels
similar to below for whilst working under the car. will let you know how I go when i get my shite together
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5034117
ok so tonight whilst the car is up on stands i thought i should get the carbon air intake installed, sometimes i wonder why i get into doing these things!
but here we go......... (better be worth it)
Martin where is my updated tune! lol.
Edited by LSX-438
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5035360
Dunc,
Hats off to you mate, it is at this point I would have another kidney tray with a whole range of nuts and bolts that are left over and I am not sure where they go.
Thanks Gibbo!
Not finished though! still got a bit to get through before the first round this sunday, going to tackle these tonight...
Yes, have a stripped stud or two AGAIN as well :( plus new j-jooks and pads
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5036588
Some of the bolts and plastic clips are getting a bit worn, so i had to source some (for the various covers atc under the car) thought i better do it whilst they are all off the car now. This is what seems to work (see pics also):
M8 x 16mm
M6 x 25mm
I picked up some high tensile ones as that is all i could find, however i am sure you can get some regular ones cheaper. The bolts are about $4~$5 for a box or 5 or 10. I noticed some of the OEM bolt heads were a bit scratched up and i couldnt use the socket on them (too damaged) so perhaps the high tensile ones wont disentegrate so easily? i dunno we'll see.
I sourced the bolts from Supercheap (i guess you can get them almost anywhere) and the plastic clips (not sure what they are called!) from JustJap in Sydney.
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5036611
Because jack stands just brake everyday and all 4 fail at the same time?
You can't be serious.
I had a bunch of dramas today, snapped caliper bolt!!
How'd you manage that, did the jackstand break on it?
Edited by GHOSTrun
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5038690
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
