  • Replies 71
Dont take this the wrong way, but 160k car, $80 stands, ive seen them break
I certainly wouldn't creep under a 1800kg (less 4 wheels!) car standing on 4 matchsticks.
That is exactly how my wife became an orphan at 8 months.
Sorry mate, you should think of your beautiful son, it's not worth the risk!
Edited by GT-Ricer
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5028993
I already mentioned you should use the floorjack as a backup on the front or back. What kills people in this situation is... no backup / SINGLE point of failure. 100% of the time.
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5029107
Good luck with the project!!!
What are your reasons in choice of pads? Endless, Project Mu, Ferodo, etc...
I am going with AP rotors and some Hawk pads. No great science/research on my part i am just going on a recommendation from a friend who is around brakes + race cars as his job. See how it goes i guess.
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5029109
Nice!
Let us know the result in the difference of the pads and rotors, stock to aftermarket.
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5029955
Duncan your a brave man to be tackling this project on those stands even with a floor jack as a safety!! Good on you dude.
Ive done the AP J hook rotors, Carbotek 12 (yeah they squeal like a bitch) and Stillen braided lines and now the braking is simply amazing. The pedal has so much bite that it just hauls the car down from 200+ to 50 in a couple of seconds. If you have a spare $300 get some stillen braided lines cause when i compare my brakes to 09 GTR who has the similar set up my pedal is def stronger which would be good for your sprints.
Edited by White 35
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5032822
Duncan you have inspired me to harden up and screw the nissan warranty in view of some track work this year
I think it's great guys getting into the track work and basic maintenance themselves :thumbsup:
this thread got me thinking what I would do when I have a tool around under the car next month
I have on order some 5T truck jack stands (pin not ratchet) for work with the wheels off and some wooden blocks for under the wheels
similar to below for whilst working under the car. will let you know how I go when i get my shite together
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5034117
ok so tonight whilst the car is up on stands i thought i should get the carbon air intake installed, sometimes i wonder why i get into doing these things!
but here we go......... (better be worth it)
Martin where is my updated tune! lol.
Edited by LSX-438
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5035360
Dunc,
Hats off to you mate, it is at this point I would have another kidney tray with a whole range of nuts and bolts that are left over and I am not sure where they go.
Thanks Gibbo!
Not finished though! still got a bit to get through before the first round this sunday, going to tackle these tonight...
Yes, have a stripped stud or two AGAIN as well :( plus new j-jooks and pads
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5036588
Some of the bolts and plastic clips are getting a bit worn, so i had to source some (for the various covers atc under the car) thought i better do it whilst they are all off the car now. This is what seems to work (see pics also):
M8 x 16mm
M6 x 25mm
I picked up some high tensile ones as that is all i could find, however i am sure you can get some regular ones cheaper. The bolts are about $4~$5 for a box or 5 or 10. I noticed some of the OEM bolt heads were a bit scratched up and i couldnt use the socket on them (too damaged) so perhaps the high tensile ones wont disentegrate so easily? i dunno we'll see.
I sourced the bolts from Supercheap (i guess you can get them almost anywhere) and the plastic clips (not sure what they are called!) from JustJap in Sydney.
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5036611
Because jack stands just brake everyday and all 4 fail at the same time?
You can't be serious.
I had a bunch of dramas today, snapped caliper bolt!!
How'd you manage that, did the jackstand break on it?
Edited by GHOSTrun
https://www.sau.com.au/forums/topic/303133-my-r35/page/2/#findComment-5038690
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
