  • Replies 107
If you're experiencing bad fuel economy, try replacing the oxygen sensor if it hasn't been replaced in the last 50,000km (or if you don't know whether it has been replaced or not). $120ish item, extra 100km to a tank...and it's quite common for them to be worn out.
lol... not too many 300rwkw cars running an O2 sensor mang....
mine got disabled years ago
oh and FWIW i get ~350 per tank... (RB25 @ 285rwkw/19ps)
Ahh read thread ffs. I didn't direct that at Chris or I would have quoted him!
I'm burning up here.
:P
out of interest, why dont/cant you run an o2 sensor?
Edited by Peter89
My car is doing 0km per 0L at the moment >.> Too busy sitting on a train that smells like bad breath.
Which train you catching at the moment, Chuck? I'm working in the city now so am training to work at the moment.
Although I'm taking a squizz at a 98 zx9 tomorrow (kawasaki...*shudder*) so this may be my last day on 84 wheels!
lol...
Peter - RE: O2 sensors, if the tuner has adjusted all the cells sufficiently, the O2 sensor can be made redundant.
All the O2 really does it on light load leans off mix and so on by way of mapping. Nothing you cannot do via a tune in the light throttle/load cells far as i understand it.
My car generally gets as good or better economy than cars with less power and O2 sensors :P
Ok,
My fuel economy is 'I don't care'
What I do is put petrol in the tank, drive it and fill it up when it's almost empty.
Simple really.
  • 1 month later...
Mine is pretty poor!! I am getting about 19-21 L/100ks
I am ALWAYS at the petrol station!!!
:D not so flash for the wallet
You need to get the car check ASAP if you haven't done so already. You are spending too much money unnecessarily on petrol. Skylines can do much better than that.
Comparison for fuel consumption is a good exercise because you get to see how well most Skylines run over time, especially with such contrasting setups. The newer cars like the R34 should have better fuel economy, whereas the older models if well maintained/serviced should perform almost as good. 400-450km to a tank sounds like the average for skyline drivers.
During my drive to Sydney I managed to get over 600km to a tank on V-Power and about the same amount on the drive back to Melbourne. This is a stockish untuned R32 GTR and driving a constant 110km/h in 5th gear (which every GTR should be able to do or better).
My next car BTW is going to be an R35 GTR, it averages 12.7 lt\100km and goes waaaaaaay faster than my car.
you drive a roadtrain?
Actually I did the maths wrong. It's 96 wheels :)
6 carriage train, 16 wheels per carriage :D
But I'm doing the 2 wheel commute now. Sooo much faster, and more fun, than 96.
If anyone sees a blue '98 ZX9 weaving through traffic somewhere between Hurstbridge, Ivanhoe and the City (Collins St) gizza wave, and get outta my way :)
For some reasons, I seemed to get more k's from a tank of 95 than a tank of V-power, why is that?
Difference is 10.5L and 12L
maybe you drive it a bit different because you know you just put in shitter fuel?
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
