  • Replies 846
Posted Images
Hey Luke
Just wired through $200 to the account mate.
Description - Krishy Track Day
You guys should be able to get it by tomorrow.
Ruby can you please check that tomorrow and let me know via a PM.
Thanks
Krishy
what track pads should i buy for the 33 GTST? want to use em on the road too, have previously used s tune pads
Hey cosi mate i got QFM A1RM and they will do fine for both street and a bit of track work......you will also find a lot of people on here are using them....i paid $238 del for all 4 sets....of GSLrallysport (not too sure of the username) on here.....go back afew pages on here and you will find a link to him.....i just PMed him and customer service is very good
Fair enough Krishy. Have you used these pads at the track before though? or has anyone? whats the brake fade like?
Congratulations to David (writeoff) for winning the track day raffle. He will now participate at the low cost of $5. Mind boggling as to why more tickets didnt sell, even to those who had already paid and/or entered, surely the $5 gamble is worth saving hundreds.
Again, Congrats David from the exec :cheers:
Thanks Damo.
Congrats David have fun :D
Thanks Steve - it was the early positioning on the sim that resulted in the ticket being bought when it was. I was so hot after my run that I needed a drink. Only had a tenna so said that I'd grab a ticket as well. Worked out rather well for me :cool: and makes up for my poor times on the sim (although they would have been better if I hit the brake pedal instead of the clutch pedal).
want a spot... booked the day off :cool:
Speak to the execs as there was a spot reserved for the winning raffle ticket and I already had a place and had paid for it.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
