I was gonna go bendix but was politely guided in the direction of QFM a1rm's. There cheap to.
hahaha good man......i ran lucas pads last track day and i had brake fade on me on the last hotlap that i was on for the day.....they did alright for that day but not using them for this track day as i have heard of too much good things about the a1rm so giving them a go.....cant wait now for the track day as car is almost ready to rock and roll
  • Replies 846
Posted Images
you have 3 weeks including this week......i would also suggest that you get yourself a set of braided brake lines
something like these..... http://cgi.ebay.com.au/HEL-braided-brake-l...=item3caa69913d
bought them for my car and they bolt up no probs
i was going to get the set from just jap but found this set for way cheaper $399 compared to $165.....quality is good i like it.....and no stuffing around involved......i repalced my lines, pads and new brake fluid all up for
- $165 for lines
- $238 for pads
- $40 for 2 bottles of penrite sin 600 brake fluid
- $50 for a carton of beer
and all done within couple of hours....and the pedal feel is amazing
im gonna end up runnin outta cash to rebuild my 32 brakes (need pistons and seal kits $400 alone on trade price let alone new lines, rotors and pads aswell) the car currently has ca brakes on it, i lost my licence 5months ago so im not missing this track day, i dont care if i gotta take it easy.
If i take 2 sets of new brake pads out there u think that will be enough? i kno the ca stoppers wont be the best but its better than not driving at all, like i said id rather take it easy than not drive haha.
Who's ripping you off with that price?
http://cgi.ebay.com.au/NISSAN-300ZX-Brake-...=item1c10696de3
Or are you saying that you have to replace the pistons themselves?
- $165 for lines
- $238 for pads
add to that a master cylinder stopper and you have a wicked brake set up for street and light track work
thats what i am going to be getting next just done have the time or $$ right now to do it specially when i am going to fiji next week
ps anyone know off where i can get a master cylinder stopper for a R33 GTST S1???
just paid for my front brake pads from gsr...
went to look at the car today and woop its all done, tune tomorrow and im set..
oh does anyone have the gasket that gotes between the stock rb25 s2 BOV?
cheers
Got my pads today :blush: got A1RM's for the rear and i'm trying the comp 9's for the front. I should get braided lines and stuff but i dont think it will make to much difference, I really need to up size brakes.
Edited by DSTROY
cheers
Booking the RDO off tomorrow. Can't wait for ext gate!
thats bullshit cheap. shall have to look into them.
Krishy, how long did it take to recieve these lines from uk? And are they defently stainless stell or tin wrapped?
UK!? The Braided Lines Krishy linked, come from Queensland, i ordered a Set on 17-03-2010...sent payment, haven't been posted yet :blush:. My guess is they are making them up, so should be posted sometime next week.
As far as Brake Seals go, i am looking at these or getting off my ass and ringing Nissan.
cheers
is there a gasket? mine doesnt have one, granted its a different engine.
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
