doubt it, the high maintenance costs have been as over exaggerated on the interweb as 2012 end of the world conspiracies
im figuring gfc for the main part, end of lease for the 09s perhaps
Edited by domino_z
Saw a clean black 35 with custom plates on the cnr Shirley and Aiken rds, can't remember exactly what they were. I've seen the same car around before (got a wave). Looks the goods.
Edited by n11smo
thread bump
haven't seen an R35 on the road for months
seems they're all on carsales
I see a gunmetal GTR with H8 TAX plates on Preston Rd Manly in Bris on occasion. I live just up the road. Might drop in for a chat next time I see it :whistling:
Who spotted who? LOL
Mick pulled up behind my N1 (whilst I was munching on my Sausage and Egg McMuffin) and wondered what it was.
Nick fellah Mick...
^ ^ ^ Yes, they're both nice - both spotted!
Terry, I luv your n1...its a classic!
What would u expect to pay for an n1 these days in pristine condition like your example?
Nick fellah Mick...
Gunmetal (so I thought it was in the dark) R35 going eastbound on the M2 tonight (7-8pm). I thought the plate was "R35" but I might have just seen what I wanted to see???
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
