Pity the food dump isn't for sale,,,I would have bought it and fed those 2 lazy rip off bitches that run it brick by brick. I gave the head scank a serve today and she will get another tomorrow.
GREAT racetrack but the rest out it is/was/always been bloody crap.
Neil.
Neil.
you arnt wrong...fark me sidways they have an attitude problem!
Neil.
I once ordered a chicken roll there and found a hair in my food, and one of those moles goes "it's from the chicken" and I go "chickens have feathers not hair"
stupid mole.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
