Hey guys
so ive been informed by my tuner that my GT3071R is on its way out... and he has highly recommended that I buy another turbo because my current one will not last longer than a few weeks... He doesnt believe (and I agree) that we should rebuild the current one as it will not be feasible
So I'm now after an internally gated GT3076 (figured might aswell try to get some more power if im gonna spend all that money)
tried to do a search on here but im getting like 24 pages of results so yeah
since I bought my turbo 2nd hand off a guy on SAU, I have no clue where to shop for turbos
besides nengun and ebay the only place I've found is www.tweakit.net
I could ring around turbo shops like GCG and all that, but does any one have any websites that I can go to compare prices?
Cheers
U
https://www.sau.com.au/forums/topic/304595-where-to-buy-a-turbo-from/
If your turbos is still making boost without too much noise its lot cheaper to just get it rebuild with a new set of Garrett bearing kit which will cost only $660 assume your stock wheels and housings are in ok condition.
We will email you a inspection report before starting any work. So you know what you will be paying and why your turbo has failed.
Can vouch for Horsepowerinabox http://www.horsepowerinabox.com/, established company been around for ages, plenty of their turbos in some great machines.
I prefer to buy from a company thats been around for a while, last thing you want is something with an ebay knockoff in it.
If you want to rebuild your turbo I also reccomend GCG http://gcg.com.au/
Rebuilds are expensive unless it's just bearings is that right? I was under the impression ball bearing turbos weren't worth doing anything to once they start to get play. It's usually cheaper to just buy another one.
Also a GT3076R internally gated can be done. To open it up properly an exernal gate on a high mount would be better though. What turbo manifold you running? What's the size of the engine? RB20 I would recommend the 0.63 A/R @ 21 PSI but an RB25 could take the 0.82 A/R @ 24 PSI with the extra displacement.
As for turbo purchases these sites listed already are the ones I know of unless you go on another forum hunt.
Edited by Ruff Ryda
^ Nope.
It's 100% cheaper to rebuild. The Garrett cartridge itself is around $1000.
Add in balancing and refit, you're saving at least $500. You get to use toye housings, and wheels again.
Send it to GCG for the rebuild, they have the best equipment in the country.
They will also be able to provide reasons why the turbo has become tired/worn in the first place - and IMO this is the [/b]most important thing to know.[/b]
There is no reason a ball bearing turbo should fail without a ridiculous amount of KM's on it, or extremely poor car servicing routine.
wow thanks for the reply guys, will definately enquire about rebuilding the turbo...
when i gave it to the tuner, it was making boost just fine, but was just taking forever to hit full boost (was getting full bost at like 5500RPM, something to do with a leak near the wastegate) so when he took it out to get it bushed, he got a "turbo expert" to look at it and he said it was about to go...
so Im gonna have to stop by and see whats actually wrong it it.
its a GT3071R, and it made 260rwkw
stupid question, but can I hiflow it or getting bigger internals for the turbo...
wanted to hit my goal of 275rwkw (i know its only a number but I feel like I didnt meet my objective)... might as well give it a crack while the turbo is out
GCG are probably the best ppl to talk to about this right...
I'll assume it's an RB25DET according to your pic. If so you sohuld be able to hit over that figure with step 1 cams (290 RWKW or so?). The GT3071R is a great turbo for response and power and work better with cams. Get some step 1 cams so you keep VCT too :P. Get a set like these:
http://www.nengun.com/hks/camshafts-nissan
They drop right in, keeping VCT and no need to upgrade valve springs unlike the larger step 1s such as JUN or Tomei. Get a Rocker Arm Stopper kit just in case for another $80 and you're set.
Good luck.
Edited by Ruff Ryda
get a dyno sheet to read 275rwkw mate, same thing. As honestly to get hung up on a number is stupid.
One dyno will say 260, the next will say 275. So who cares?
Rebuild it as is, or be prepared to hurt response by going to something bigger.
As for CAMS - they will not magically get you to 290rwkw, so i totally disagree with the post above this.
I made 370rwkw through factory RB25 CAMS. Same as Guilt-Toy has done with a 25/30 and a GT35.
They are not a problem.
Cam haters. ;)
I'm not sure who thinks they magically add power........ :D
I reckon there is about 10-15kw going to 256 deg poncams but whether it is worth it is an entirely different question.
I would rebuild the turbo, re-tune and be happy or spend the extra money on buying a GT3076 if you want a bigger number.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
