Rate My Skyline
  • Replies 211
Posted Images
No need to turn this into an R33 hate fest. :)
no hate fest here.... ive harpooned a whale before... let it go though.. best it could do was 12.01 1/4... just could not get it into the 11's, but then again, i had a gtr wang on it.... good for track work and cutting through the air around corners, not good in a straight line though.
drftin33.... you're different... the rest of us are mostly the same.
When you prove you've spend 50k, and have 250rwkw with a stock turbo...
maybe... just maybe... we might.
but i doubt it
hmmm when i ay 50k thats all up +te car its slef and when i say 38 grand i havereplaced evry thing under bonnet down to heater core al new tubing timing/+ the car was stolen at one time and i had to fix my kit and respary nelly evey panal and whn i say 250kw itht was wit last motor when i go it it had the dyno sheet and he said with stock turbo and i thout h new hat he was talkin about and we tested to down te1/4 male we put he bosst up to and finshedthe motor off i dont lie dude i will gt more pics when is back and i do own it
and btw wat wheel would you say for a skylin=p
what part of skyline yo want pics of gana take 2 days don have car atm
Dude, type normally for f**ks sake, we speak clear English on these forums, not txting your 10 year old boyfriend to come round for a quickie. Is it really that hard to type a coherent paragraph?
its not but my key board s stuffed when im typing noall my keys work :)
learnt t tipe plz k thx
I miss letters and make typos sometimes too... Do I just skip them and leave some abortion on the forums for people to step in? NO! I fix them...
One coherent f**king sentence from you would be great...
yea if you can be stuffed dont really have the time on my hands but ill try harder sorry :)
 Share
    • Hi mate, I have never had an issue with the odometer in mine (450,000+ klm now) and can't remember another post about it. Still, your description of the likely cause sounds spot on, so an electrics repair is probably the next stop.
    • Cheers. I more want it quieter with the varex open. I only have the varex closed when i start up and roll out the driveway to keep everyone happy on days i take the car to work at 5 AM or come home late. So just a mod muffler will do tge trick? Something like that would require a retune hey?
    • I was going to say generally speaking if it's like 80k+ miles since the valve cover has been replaced you don't even attempt to just replace the gasket. The valve cover itself will likely be warped and it will continue to leak after replacement, just not as severely. The valve cover PCV diaphragm can also tear and create a major vacuum leak. Welcome to BMW life. My friend's 2006 330i was t-boned and totaled out so he also just got a 335i so I can add to this thread now.
    • Hi all, For my '98 260rs... The odometer LCD occasionally turns blank or gives me only the bottom half or top half of the numbers. It's intermittent, which leaves me to believe it's a dead solder or loose wire somewhere. The odometer itself works. When the screen comes back, kms have been added to the trip and overall meters. A couple questions: Is this a known issue with the Stagea? I didn't see it pop up in my quick search, but that could be my searching skills. How accessible is the LCD screen in the cluster? I'm hoping it's a remove and replace type situation versus cracking open the whole housing. I'm hoping you all can narrow some of my initial troubleshooting. Any experience or opinions would be helpful.
    • Yeah. Seeing the finish line must be quite the motivation. Good on you for sticking with it. Understood about the model choice. Also, totally get the challenge with sourcing parts. Based on your handle, I'm just a few hours south of you. All the little things I've bought so far come with $30 shipping, even if it's just stickers for the boot!
